I got a LED light bar to be mounted below the tailgate. It is advertised as having a running/parking light function (all red LEDs lit at low brightness), a brake light function (all red LEDs lit at full brightness), sequential amber turn signal function, and amber hazard signal function. It has a 4-pin connector to plug into the trailer hitch connector or can be hard-wired into the taillight wiring.
I first plugged the light bar into the trailer hitch connector and could only get the running and brake light functions, no turn signals or hazard lights.
I spliced the light bar wiring into the truck wiring and got the same results. Tried it with and without resistors.
During this process I tested the wiring at the back of the truck and I have correct voltage to running, brake, turn and hazard lights (intermittent voltage to turns and hazards).
The vendor told me to connect the light bar directly to the battery to determine if the bar was defective. I connected the ground lead to the negative post with a jumper and then connected each of the other leads one at a time with another jumper. Running and brake lights worked as they had when connected at the rear of the truck. When I connected each of the turn signals I got a brief amber signal that immediately changed to all red at full brightness. Same result on hazards. If I touched the jumper briefly to the positive post I got amber lights.
The vendor then said I needed to change my flasher to an electronic flasher to make the light bar work. Since our trucks do not have flasher relays (controlled by the BCM) that is not an option.
Looks like I’ll be returning this light bar.
