1 - 4 of 4 Posts
Long time lurker, fairly new to posting here. The Colorado was suffering from a burned out brake light bulb, so figured I'd spend my efforts going LED out back. I ended up going with a newer style CREE lens/Q5 LED bulb, but the installation and general setup is the same as Greg's writeup in the Tech section. These bulbs are at least 2-3 times as bright as stock and the look they give is killer. Got the whole mod done for $100, way less than new LED lenses and get to keep the overall stock appearance. Got everything buttoned up in about 45 minutes. Here are links to what I bought...
Brake/signal bulbs:
3157 Red 25W CREE High Power LED Projector Red Blinker Turn Signal Lights Bulbs | eBay
Backup bulbs:
3157 3156 High Power CREE LED Projector Xenon White Daytime Running Lights Bulbs | eBay
Resistor package:
2X 6ohm 50W LED Load Resistors Turn Signal Blinkers Fog Lights Fix Hyper Flash | eBay
Here's a link to my reply in the tech section that shows pics of the packaging and the bulbs up close:
http://www.355nation.net/forum/how-...3057-led-bulbs-tail-lights-3.html#post3165985
Nice job. I switched to the projector style LED bulb as well for the reverse bulb. I need to do it for the other bulbs too since I'm now running tinted lenses.
Discussion Starter · #4 ·
Don't know if I'll ever do tinted lenses, but the projector bulbs seem to be much brighter than the other styles. The 25w bulbs I used would work with tinted lenses, but might as well go bigger if you're going to replace them anyway.
1 - 4 of 4 Posts
