1 - 20 of 25 Posts
Ever since a saw a pic of ahelm3's 2009 LH8 engine I've been curious about the air flow indicator on his truck and why my 2009 LH8 doesn't have one.
@ahelm3
Well, from what I can tell GM had these air flow indicators on the early LH8 motors (2008-2009) and then sometime mid-year of 2009 they redesigned the airbox and eliminated the airflow indicator. Guess this makes the early LH8's even more rare.
Here's a pic of the original first design... take notice of parts #4 and #5.
AIR INTAKE SYSTEM. Fits: CANYON, COLORADO, H3
and here's the 2nd design without the indicator:
My truck was built in May 2009 and and doesn't have the air flow indicator.
I would think that anyone with the LH8 or LH9 could add this air flow indicator simply by drilling a hole in the air box and adding the grommet and air flow indicator. I suspect that the air flow indicator is a visual indicator the helps you determine when it's time to replace your stock air filter or clean your K&N filter.
Item Number: 004
Part Number: 25861130
Description: GROMMET. Air Cleaner
GROMMET,A/CL AIR RSTN IND. Required: 01
For: N1 5.3-L(LH8) (2009-2009) (2009 - 2009).
For: N153(06) 5.3-L(LH8) (2008-2008) (2008 - 2008).
For: ST156(43-53) 5.3-L(LH8) (2009-2009) (2009 - 2009).
Cost: $5.09—$7.72
Item Number: 005
Part Number: 25813591
Description: INDICATOR. Air Cleaner
INDICATOR,A/CL AIR RSTN. Required: 01
For: N153 5.3-L(LH8) (2008-2009) (2008 - 2009).
Cost: $36.01-$54.57
I thought I read somewhere that only trucks with the optional heavy duty air filtration came with the air flow indicator....regular/standard air filtration did not.
Discussion Starter · #4 · (Edited)
I never heard of a "Heavy Duty Air Filtration" option and the only difference that I can see is the addition of the air indicator. Otherwise there's nothing "heavy duty" going on here.
I suspect that this was just another cost savings thing that GM implemented in 2009. Kinda like the lack of footwell lights, coin holder and silicone inserts for the cup holders, etc.
@Decoy Jay has one on his. I was under the impression that it wasn't all that accurate and as long as someone changed their air filter at the recommended intervals it would never read anything.
If your customer doesn't have a device to counteract what you tell them is time to replace then you can get more customers to pay the price to replace it and make the profit. Thus r3moving it killed 2 birds with 1 stone. Less money to build, and added profit during recommended repairs at service intervals.
GM may not have offered heavy duty air filtration on the 355.....IDK. However, they definitely offered it as an option on full size 5.3L trucks.
Discussion Starter · #9 · (Edited)
When to Inspect the Engine Air Cleaner/Filter
If your vehicle is equipped with an air filter restriction indicator, it lets you know when the engine air cleaner/filter needs to be replaced. On vehicles with a restriction indicator, you should inspect the air filter restriction indicator at every oil change and replace the engine air cleaner/filter when the indicator tells you to.
How to Inspect the Engine Air Cleaner/Filter
(Vehicles With an Air Filter Restriction Indicator)
Locate the air filter restriction indicator on the engine air cleaner/filter cover. When the indicator turns black or is in the red/orange “change” zone, replace the filter and reset the indicator. See the steps following to replace the engine air cleaner/filter and to reset the air filter restriction indicator.
Intersante. Went to go take a picture for ya, but all my tools are at the new house and my pap's toolbox is a hot mess.
Nation Lurker
My truck doesn't have the indicator and I got it in Nov.'08.
Got mine Dec 08, build date was Oct 24, 2008 and I also do not have this indicator.
Yes, your special Alex @ahelm3
:rtardc: Well we knew that already :rtard:
:lol:
Neat addition Rich
1 - 20 of 25 Posts
