1 - 6 of 6 Posts
I was just driving down the highway when my brake light came on, then all My gauges shutoff. I pulled over and shut the truck off and it would not restart until unhooking the battery. Now the truck will not shift into OD. The pcm was just tuned. Bad pcm? I have a loaner pcm in there right now.
Only other thing done to the truck recently is a remote start was installed.
Discussion Starter #2
Sounding like remote start from what I've read. It's causing the transmission to not get power and go into limp mode. Also cutting power to the cluster.
Anyone had any similar issues with remote start?
Which remote start?
Installed by?
Members Technical Staff
Have you checked to make sure all plugs and connections are tight?
Discussion Starter #6
Truck was doing same thing this morning then all of a sudden it dropped into od doing about 80 and now it's working fine. Having the remote all checked out tomorrow
1 - 6 of 6 Posts
