*LOWERED PRICE 7/9* Complete Turbo Kit, 3" Exhaust, Manual Trans, 3.5/3.7 I5 Parts
9240 Views 68 Replies 21 Participants Last post by  Binyled
8
This kit is as complete as you can get, it has everything you need to make over 400HP at the crank. All name-brand high quality parts, no chinese knock-off junk. Turbo is the perfect size for the I5, very quick to spool but not like a light-switch. Whoever picks this up is getting a steal.
$2999 (buyer pays shipping) - Complete Turbo Kit Ready For Install
  • Custom Log Style Turbo Manifold w/ T3 Turbo Flange and 38mm Wastegate Flange
  • Precision PTB400-6162 Turbo w/ S" Compressor Cover (4.0" inlet/2.5" outlet) and T3 .82 A/R 3" V-Band Discharge
  • Custom 3" Downpipe
  • TiAL 38mm Wastegate w/ 10psi spring
  • TiAL Blow-Off Valve
  • Black Intercooler
  • Complete Cold Side Charge Piping w/ Air Filter
  • Black SSK Blade Style MAF Sensor Adapter
  • New Blade Style MAF Sensor
  • 2-BAR GM MAP Sensor
  • 3.5/3.7 Return Style Fuel Rail w/ -6AN Fitting Adapters
  • 5 60lb Injectors w/ Correct Injector Harness
  • Aeromotive 13107 Rail Mounted Fuel Pressure Regulator w/ Gauge
Great for someone looking to do an Automatic (4L60E) to Manual (AR5) swap. Shifts like new, just changed fluid 5000 miles ago. Ready to go!
$650 (buyer pays shipping) - Colorado Manual Transmission w/ Flywheel and Clutch
  • Aisin AR-5 Transmission
  • 3.5/3.7L Flywheel w/ less than 5000 miles
  • 3.5/3.7L Sachs Clutch w/ less than 5000 miles and zero clutch dumps
  • Slave Cylinder w/ less than 5000 miles
$175 (buyer pays shipping) - Custom 3" Exhaust Ready for Install
  • Complete Custom 3" Exhaust for 2.8/2.9/3.5/3.7 w/ High Flow Magnaflow Muffler
Prices below exclude shipping costs:
Stock 3.7L Intake Manifold - $50
Stock 3.5L/3.7L 8-pin (2004-2007) Throttle Body - $50
2007 3.7L Automatic Complete Engine Wire Harness (Also works with manual transmissions) - $150
200F 3.5L/3.7L Thermostat (Less than 5000 miles) - $20
3.7L Valve Cover - $50
5 (Five) 3.7L Coilpacks (Less than 5000 miles) - $75
I5 Returnless Fuel Rail - $30
2007 Alternator - $50
2007 A/C Compressor - $100
3.5L/3.7L Water Pump - $25
More parts will be added to this listing. Stay tuned!
Status
Not open for further replies.
1 - 20 of 69 Posts
Re: Complete Turbo Kit, Transmission, Clutch, Flywheel, and Things
Damn if only I hadn't went lifted lol. Why are you selling? Just curious.
Hmmmmm
Kent, do it.
Exact setup as mine (almost I'm using a bigger wastegate) I feel confedent In this set-up seeing as I've been running it for awhile now. And It does put up 400 at the crank @11 psi. Which is safe. I promise :) that's all on stock fuel pump @93 oct.
Good luck and good buy!
I wish I had three grand
Don't tempt me Levi....don't tempt me lol
Very solid kit and components. All you need is a good tuner and you're set.
Damn it damn it damnit damn it!!!!!!!!!!!!!!!!!!!!!!
I wonder how that would run on a 5.3....probably a little small maybe...?
not to mention you'd only be able to use half the things he's selling.
True...true....but still a turbo would sure be fun.
Re: *UPDATED 6/26* Complete Turbo Kit, Transmission, 3.5/3.7 I5 Parts
I'll maybe take it off ur hands man for my cousin lets see if I can get some funds quick
i would so buy if i had the cash to put a new motor in if i blew mine
GLWS
That would be neat.
Need this gone!
Turbo kit is an incredible deal!
Transmission is an excellent deal for someone looking to do an automatic to manual swap! These trucks are anemic with the 4L60E, the Aisin AR5 really puts some pep in their step! Includes Clutch, Flywheel and Slave Cylinder with low miles (HUGE SAVINGS!)
1 - 20 of 69 Posts
Status
