1 - 14 of 14 Posts
X
you can get 2'' lowering springs but for 2'' you will need balljoint which will give you 2'' and then 1'' springs for 3'' or 3'' control arms from DJM... idk how you would get 2.5'' unless you cut your factory springs with the balljoints....
thanks man, i didnt think they would make it, but wouldnt i be able to put a 2" drop in the front with just springs?
By the looks of your avatar and sig, you have a Z85, correct?
If so, you'll want to go with the Belltech 4203 coils. That will give you a 2" drop.
For an additional 1/2" of drop, you'll need to cut a 1/2 loop.
No one makes 2.5" drop coils for these trucks. ;) However, you can go with coilovers and that will give you the ultimate suspension control.
hmmmm, thanks alot man, where could i get the coil overs, or what do you recommend getting?
It really depends on how much you're looking to spend.
2" drop coils are about $100-$110.
Coilovers are MUCH more expensive.
For the galvanized Belltechs, they go for about $500-$600 for the fronts only and are height adjustable only. The stainless version which also has adjustable dampening, goes for about $1200-$1300 which includes front and rears.
X
how much did you say the stainless ones are... is that the ones for 12oo???
Quadruple O.G.
Get 15% off* your order of $100 or more at Stylin' Trucks. But hurry – the Yuletide clock is officially ticking and our 15% off sale ends tonight at midnight!
Use coupon code WRAPUP during checkout to get your 15% discount.
Front Galvanized and rear lowered shock http://www.stylintrucks.com/parts.a...trigger=&selected_prod_ids=1920&partid=525600
$719 - 15% = $611.15
Just the front galvanized front shocks
http://www.stylintrucks.com/parts.a...trigger=&selected_prod_ids=1920&partid=525592
$589 - 15% = $500.65
Front adjustable stainless steel coilovers with ss rear adjustable shocks
http://www.stylintrucks.com/parts.a...trigger=&selected_prod_ids=1920&partid=525615
$1399.99 - 15% = $1189.99
Tom at street beat MAY be able to beat these prices but you will have to call him and ask :355:
1 - 14 of 14 Posts
