1 - 20 of 63 Posts
Quadruple O.G.
Lowering Suspension Products and Part Numbers Help Guide
BellTech SuspensionsBell Tech Corp
Ball Joints, Springs & Shocks.
  • 2” Drop Ball Joints Part# 2103
  • Drop Front Shocks 0"/-1"/-2" Part# 25005
  • 1” Regular Cab Front Springs Part# 4201
  • 1” Crew Cab and Ext Cab Front Springs Part# 4205
  • 2” Regular Cab Front Springs Part# 4203
  • 2” Crew Cab and Ext Cab Front Springs Part# 4206
  • 1" or 2" PRO Kit for Regular Cab Part# 12203
  • 1" or 2" PRO Kit for Crew Cab and Ext Cab Part# 12206
    **Pro kit Part#12203 consists of lowering springs, Spring Distance Spacers and Leveling Spacers.
  • 2"-4" Rear Street Performance Shocks Part# 220896
  • Rear Nitro-Drop Shocks 3”-5” Part# 7503
  • Rear Nitro-Active Shocks 3”-5” Part# 10503
Coilover Kits
  • 0-3” Front Shock Coil Over Combo Height Adjustable (Fixed Damping Galvanized) Part# 12001
  • 0-3” Front Shock Coil Over Combo Height Adjustable (Fixed Damping Galvanized) with rear shocks Part# 13001
  • 0-3” Front Shock Coil Over Combo Height Adjustable, Damping Adjustable and Stainless Steel w/ Rear Damping Shocks for use with lowering leaf springs Part# 21001
  • 0-3” Front Shock Coil Over Combo Height Adjustable, Damping Adjustable and Stainless Steel w/ Rear Damping Shocks for use with factory leaf springs Part# 21003
Lowering Blocks and Leafs
  • 1” Lowering Blocks W/ U-Bolts Part# 6010
  • 2” Lowering Blocks W/ U-Bolts Part# 6110
  • 3” Lowering Blocks W/ U-Bolts Part# 6210
  • Rear U-Bolt Kit With Hardware Part# 6205
  • 3” Rear Leaf Springs Part# 5953
Miscellaneous.
  • Front Sway Bar Kit 1.25” Diameter Part# 5421
  • Rear Sway Bar Kit 1" Diameter Part# 5521
  • Rear Frame C-Notch Part# 6603
  • Replacement Tranny Crossmember (gain 2.25” of clearance) Part# 6963
  • Coil Spring Leveling Spacers (three 5/16" spacer's = 1") Part# 34932
  • Coil Spring Distance Spacers 1" Part# 34854
  • Pinion Shim Kit 1 Degree Part# 4973
  • Pinion Shim Kit 2 Degree Part# 4975
  • Pinion Shim Kit 3 Degree Part# 4976
  • Pinion Shim Kit 4 Degree Part# 4977
  • Pinion Shim Kit 6 Degree Part# 4979
DJM SuspensionsDJM Suspension
  • 2” Front Coil Springs Part# CS2400-2
  • 3” Front Lower Control Arms Part# CA2400L-3
  • 3” Steel Lowering Blocks W/ U-Bolts Part# SB2400-3
  • 4” Steel Lowering Blocks W/ U-Bolts Part# SB2400-4
  • 3” Replacement U-Bolt Kit Part# LBUBK
  • Pinion Shim Kit 2 Degree Part# ACC2PSK
  • Pinion Shim Kit 4 Degree Part# ACC4PSK
  • Pinion Shim Kit 6 Degree Part# ACC6PSK
  • Cal-Max SuperShox Rear Part# 2100
Clean Cut Creations - Clean Cut Creations
  • Tubular Lower Crossmember Kit
  • Replacement Upper and Lower Gas Tank Crossmembers
Western ChassisSport Truck Direct - Home Page
  • 3” Front Coil Spring
Jags That Run Jags That Run
  • ½” Solid Billet Lowering Block (This block can be bolted to any of there other blocks to achieve a extra ½ drop) Part# COL-504
  • 1” Solid Billet Lowering Block Part# COL-501
  • 2” Solid Billet Lowering Block Part# COL-502
  • 3” Solid Billet Lowering Block Part# COL-503
  • Heavy Duty U-Bolt Kit Part# COL-505
  • Axle Pinion Shims 2, 3 and 4 Degree Shims
  • Lower Replacement Crossmember Part# COL-550
AIR Lift - Air Lift Company
  • Air Lift 1000 Load Assist Rear Bag Kit Part# 59546
    **Note use Air Ride Technologies bag plates for 2.5” leafs when using the Air Lift Bag kit with lowering blocks. Part# A070
Mcgaughy's Suspensions - Mcgaughys Suspensions
  • 2wd Reg Cab 2/3 Lowering Kit (Coil and Blocks) Part# 33100
  • 2wd Ext/Crew Cab 2/3 Lowering Kit (Coil and Blocks) Part# 33101
AIMAIM Indus.
  • Billet Coil Over Shock Combo- Height Adjustable with Adjustable Damping and Rebound.
  • 1"-2"-3"-4" Alloy Extruded Blocks with pinion correction angle built in and with steel pins inserted for strength. Guaranteed not to break forever.
KYBKYB Shocks
  • GR2 Front Part# 341374
  • GR2 Rear Part# 344464
  • Gas Adjust Front Part# n/a
  • Gas Adjust Rear Part# 5191
MonroeMonroe Shocks and Struts
  • Reflex Front Part# 931353
  • Reflex Rear Part# 911228
QA1 - QA1 Designs
** See How To Here 1st Before Ordering
  • Front QA1 coilovers:
  • DR7855P Proma Star AL single adjustable coilover shocks - $152.95 each
  • DDR7855P Proma Star AL double adjustable coilover shocks - $275.00 each
  • 9029-146 4" Stud Mount Conversion - $26.10 each
  • 7888-110 SPANNER WRENCH & THRUST BEARING KIT - $45.95
  • *Request bottom bushing bolt sleeve 9/16"
  • Rear QA1 shocks:
  • TC1661P Stocker Star AL single adjustable shock - $139.00 each
  • DTC1661P Stocker Star AL double adjustable shock - 275.00
    Note: above rear shocks are for ZQ8 leaf springs. Belltech drop leafs may require a shorter shock and Z85 leafs may require a longer shock, which will require the upper T-Bar mount kit. Consult Naake Racing for proper size
**Prices based from 01/2008 Naake Racing Suspension Specialists - Hal / QA1 Shocks & Accessories, Ohlins Advanced Racing Suspension, Penske Racing Shocks
Universal Suspension Parts
Belltech Bell Tech Corp
  • Hexagon Button Bump Stop Kit Part# 4915
  • Cone Bump Stop Kit Part# 4918
  • Cone Bump Stop Kit Part# 4921
  • Retangle Bump Stop Kit Part# 4900
  • FOAM Cylinde Bump Stop Kit Part# 4920
  • Wedge Bump Stop Kit Part# 4903
DJM - DJM Suspension
  • Round Bump Stop Kit Part# 10R
  • Square Bump Stop Kit Part# 10S
Suicide DoorsSuicide Doors
  • 2.25" Bolt In C-Notch
Re: Lowering Suspension Products and Part Numbers
When I was Planning on giving my truck a 3"-4" drop and I could not find ANY kind of lowering Kit that would fit My suspension..... Everytime I ran across the desired ride hight that I wanted I was shot down with.....Only Fits Vehicles With Z85 Suspension, Not designed for Sport, Extream or ZQ8. Weak
awesome post brewer
It does fit -- all the trucks are interchangeable, the only thing is depending on the part, it will lower your ZQ8 (same as the Xtreme) a different amount than claimed. For instance, if you were to replace your stock coils with the Belltech 4203 coils, you would only gain about an 1" - 1.25" of a drop because your stock coils are already an inch lower than the Z85 coils.
And if you wanted a true 2" drop, you'd use the Belltech balljoints and you'd be set.
Post up a new thread and tell us how low you're looking to go and your wheel size and someone will be able to guide you through it all and get you lowered.
X
i have a colorado xtreme and i wanna lower it about 2 inches. what kit could i use to get 2 inches lower
The balljoints are between $220 and $230-$235. The blocks are around $50. Think I paid $47 for mine at summit...
thanks man i wanna go a bit lower. Ive been scrapin shit with all my past vehicals and i wanna get back into it.:lol:
are the balljoints the best way to go up front?better than coils?control arms?
X
depending on the drop. if you want a 1'' drop(dnt see the point) - coils
2'' drop - ball joints
3'' drop - control arms
4'' drop - go ahead and bag it.
btw.
the best is the adjustable coilovers by belltech
If I could do it over, I wouldn't do the balljoints again.
Too much friggin' bump steer!!!!!
They definitely give a softer ride than the 2" coils, but damn that bump steer is a bitch.
If you're looking for a 3" drop, go with the control arms.
And if you have the money, coilovers.
X
rrcn .... would u get coilovers if you had a choice?
X
i wish i had the $$ to bag mine. if you wanna bag yours and sell your lowering stuff let me know...
i am running with 20s on my coloy, and im wanting to drop 3" in the front and 4" in the back. is this posible? (my tire size is a 255/45/20.) and do they even make a kit for that low of a drop?
Quadruple O.G.
Discussion Starter #18
5cylinder and Tire slayer
wait.. I thought the Control arms were a 2" drop just like the ball joints?
1 - 20 of 63 Posts
