I am looking into purchasing thise engine for around $800 and having it fixed. Based on the description what do you think is wrong and how much do you estimate it to cost to get fixed?
Also would it be easy to change to flywheel over to an automatic trans?i have an ls1 complete less the wire harness, has 50k miles on it. has water pump, coils, powersteering, injector rail, font pulley, flywheel for standard shift trans, mas air flow, plenum. runs fine has alittle noise because a lifter went bad and messed up the cam.
