1 - 20 of 28 Posts
So I did a search and I found a lot of cool stuff I want to do with my intake instead of wasting money on an aftermarket one. The couple questions I had that I was uncertain on were some of the parts needed.
I did see some part numbers and such...I want to do the 3" PVC conduit that I saw, with a velocity stack and kn filter. Is that all I will need? And a couple misc hose clamps and such? Thanks -Eric
Quadruple O.G.
Filter, v-stack, 3" pvc pipe, three- 3.5 to 3" connectors and clamps. Now you have two choices for the rubber hose off the valve cover. One is to use a valve cover filter directley on the valve cover or insert a barb into the tube and run a piece of rubber hose to it.
Yeah, that's pretty much it. You'll need a fitting to connect the breather hose to as well, but those are cheap and easy to find.
I went with a Blox Velocity Stack, it's a little cheaper than the BPi and it pretty much the same. I already made mine but I need to paint it still, so I haven't put it on yet.
well if you want to pm me an ill tell ya how i did my pvc intake!
I assume you are going to do something like mine? I had some 3.5in to 3in silicon couplers, but I had a terrible time getting them to fit over the PVC conduit I used. Instead I used a much cheaper 3in rubber plumbing coupler from the hardware store. They had some with just clamps or the ones I used with the metal collar. I think the collar looked better and would add some support to the couplers. The rubber coupler was able to stretch more and made for a very solid fit. The outside diameter of the PVC I used was right at 3.5".
P
Dude, if i were to pay you, would you please, get me a duplicate of the pipe you used? I cant find that shit anywhere in town. :dawg: :dawg: :dawg: :dawg: :dawg: :dawg:
P
well what angles are people using, im about to go pick up the 90 degree if that is what justin used. what did you use brewer?
The 45 degree may work better if it's long enough. I only used about 1/2 of the 90 degree. When I got mine they didn't have any 45's in stock.
P
yep.
This is almost the same coupler I used. You're best bet would be to take it up to the hardware store and test fit it.
http://www.doityourself.com/invt/u341917
funny thing is, my home depot has both parts, i will pick em up tonight, i i had both of these parts in my hand a month ago in the store, i looked at em and was not sure if they would work. :shrug: now i know they will.
Thanks so much guys. Will post latta with my findings. :wavey:
1 - 20 of 28 Posts
