Makes sense... seeing as like I said max pressure for 1 atmosphere is 15psiwell my buddy thats helpin me said if i have a MAP sensor its probably only a one bar (one atmosphere) and that i would need a 2 bar (up to two atmospheres)
well thats also what this thread is here for lolMakes sense... seeing as like I said max pressure for 1 atmosphere is 15psi
I'd ask the other guys who are boosting what they did to get around this or what they bought. But thats kinda obvious...:mc:
wow really? and you have been tuned with your kit and all?Zach:
Atmospheric pressure at sea level is 14.69psia.
Here in CO it is usually around 12psia depending on where you are.
Unless you are below sea level a reading higher than that is not true atmospheric pressure. There must be some inaccuracy in your sensor or there is some pressure building from running at speed. Assuming that the reading is actually accurate then it proves how there is help from the ram air effect you love to hate; and you aren't even set up for ram air. Lol.
Skizzo:
I never had to change my map out. My MAP should be seeing upwards of 19psia (when I was down in Houston it probably saw above 21psia). I have no problems but there is one change cataloged at cfans in the sts thread that had to be made. It was just for the MAF though.
can you do this in HPTuners? and what units is "15000" and "45000" in? (i take it thats what you meant with the K)on cfans they said the main thing that was done was set the maf fail to 45k instead of 15k.
might it have been grams per hr or grams per minute?yes, can be done with hp tuners, dont remember the units.
editXHR:
You have to change MAF error frequency up like 30k to keep from hitting reduced power mode. If you change that you don't have to run a MAP clamp.
Just:I thought it was 45k but yeah that is what Stocker2 found out when he compared the w2w file.
XHR:yeah, the error frequency was 30k over the OEM set number.
Just:Oh ok, so we are saying the same thing then, just different ways?
edit:
Do you get a code when running a/c in traffic, or just "putting" around? It clears itself too but it is annoying.
:lmaow:well i happen to glance at the other site and see my answer to this topic somewhat... in the "STS turbo" thread....
Question
edit
and im an idiot.. because this was all already mentioned (and i had read it lol) earlier in this thread
reading retainment is > me
You bring these things upon yourself. Lol.Well i'm at sea level... i'll give it a run later and see what she says exactly but yeah I see around 14ish @ WOT. I knew someone would come in here and nit-pick me giving out such percise numbers...
and it was answered by the same person... but no one said cfans doesnt have good information on it....I just think its funny how a thread got started here yet cfans came through and helped lol.
