1 - 9 of 9 Posts
Found a set of these with tires locally. What I want to know is they came off of a Nissan Pathfinder. Will they fit our Colorados ? Bolt pattern is 6X114. Hope they fit. Going for a good price..
Then how can you take an older model Escalade wheel and put it on a Nissan and a Colorado, but a Nissan aftermarket wheel will not fit mine ?
Z
uhm, not a clue but our bolt pattern is slightly different from the nissan. Escalades share our bolt pattern.
I did a quick search and it revealed that the Nissan Pathfinder from 86-97 should have a 6x139.7 bolt pattern which is the same as ours. So either this Pathfinder in question does not fit in these model years or the 6x114 is completely wrong.
1 - 9 of 9 Posts
