Re: Mordis Build Thread
Energy Suspension 9.8169 - Pivot Style Universal Endlinks. Energy Suspension ENE-9.8169G
I used the same ones on the front & the rear.
Yeah like I said it wasn't too bad getting it to work just gotta reuse the rubber bushings for the mounts and of course the Valve guide in the end link hole.
Thanks Rich. I am hoping I do get some better cornering out of it. The front bar is 5/16" bigger and the rear is 1/8" bigger plus I believe the Helwig bars are chromoly which should give a little more spring rate than the standard Carbon Steel bars.
Here you go @TurboAl
