Mordis Build Thread - Supercharged 2011 Colorado
24203 Views 139 Replies 22 Participants Last post by  Mordis
List of mods that I've done to my truck. The captions are clickable to go to the post.
February 2021 - Truetrac, Ring & Pinion & Accessory Drive Fix
August 2020 - New Hood & DRL Covers
August 2019 - Push Rods & Brake Pads
April 2018 - Dyno Tuning
September 2017 - Transmission Cooler & Thermostat Change
September 2017 - Supercharger & Cam Update 14
September 2017 - Supercharger & Cam Update 13
September 2017 - Supercharger & Cam Update 12
September 2017 - Supercharger & Cam Update 11
September 2017 - Supercharger & Cam Update 10
September 2017 - Supercharger & Cam Update 9
September 2017 - Supercharger & Cam Update 8
September 2017 - Supercharger & Cam Update 7
August 2017 - Supercharger & Cam Update 6
August 2017 - Supercharger & Cam Update 5
August 2017 - Supercharger & Cam Update 4
August 2017 - Supercharger & Cam Update 3
August 2017 - Supercharger & Cam Update 2
August 2017 - Supercharger & Cam Update 1
August 2017 - 3LT Registry & My RPO Codes
May 2016 - Doug Thorley headers, Custom True Dual Exhaust with Mandrel Bent pipe & Borla Pro XS Mufflers - Day 5
May 2016 - Doug Thorley headers, Custom True Dual Exhaust with Mandrel Bent pipe & Borla Pro XS Mufflers - Day 4
May 2016 - Doug Thorley headers, Custom True Dual Exhaust with Mandrel Bent pipe & Borla Pro XS Mufflers - Day 3
May 2016 - Doug Thorley headers, Custom True Dual Exhaust with Mandrel Bent pipe & Borla Pro XS Mufflers - Day 2
May 2016 - Doug Thorley headers, Custom True Dual Exhaust with Mandrel Bent pipe & Borla Pro XS Mufflers - Day 1
April 2016 - BFGroodrich g-Force Comp-2 A/S Tires
March 2016 - SSBC Disc Brakes, Belltech Stainless Steel Double Adjustable Coilovers & Helwig front & Rear Sway Bars - Done
March 2016 - SSBC Disc Brakes, Belltech Stainless Steel Double Adjustable Coilovers & Helwig front & Rear Sway Bars - Day 4
March 2016 - SSBC Disc Brakes, Belltech Stainless Steel Double Adjustable Coilovers & Helwig front & Rear Sway Bars - Day 3
March 2016 - SSBC Disc Brakes, Belltech Stainless Steel Double Adjustable Coilovers & Helwig front & Rear Sway Bars - Day 2
March 2016 - SSBC Disc Brakes, Belltech Stainless Steel Double Adjustable Coilovers & Helwig front & Rear Sway Bars - Day 1
September 2015 - Superior Billet 2nd Gear Super Servo Kit & Billet Super Servo 4th Gear Apply Piston & Cover (No pics of the install)
August 2015 - Gorilla Automotive Acorn Bulge Black Chrome Lug Nuts
July 2015 - EZ-Down bracket & Line-X Bed Liner
June 2015 - Redline Tuning Hood Struts
June 2015 - K&N Air Filter & Air Doc intake tube.
May 2015 - Home after being bought from a Dealership in Ohio
61 - 80 of 140 Posts
Re: Mordis Build Thread - New Exhaust.. Headers Installed!
A little update, the cat. monitor spacers with the smallest inserts didn't work it threw codes on both banks so my uncle is going to bring home his scan tool that will tell us exactly what voltage the sensor is reading then we will probably try the medium size insert and see what happens.
What codes? If it is a p2270 then you need to run no insert. I have the same spacer.
Na the codes were P0420 & P0430.
Right on, So I haven't updated this in awhile because really I haven't done much to the truck since the exhaust. I still have the Cat DTC codes which will be gone soon and I spent most of the summer camping & working. So now that it is getting colder again it's time for more "things" and I decided to start with a big "thing"
Of course more pics will come when ever I get ready to install it, I still have to ship the PCM/TCM to Magnuson for programming then get a weekend to install it.
Re: Mordis Build Thread - Boost...? Boost!
love it!
Thanks, I'm pretty excited.
Haven't really done much with this in awhile, Gonna be starting a big project on the engine soon as can be seen a couple posts ago that project has grown from a Supercharger kit to a whole lot more, but more on that later.
But for now decided to join the 3LT Registry that @FrEaK_aCcIdEnT started. Like he said in the first post there is no production numbers for 2011 which sucks but at least it's a nice list of my RPO codes.
Big Thanks to FrEaK_aCcIdEnT for pulling this info.
Ok so like I said in the last post I'm finally starting my engine project It started as just a Supercharger kit from Magnuson but then I decided since I'm in there might as well do a cam and some other things. The only thing I have bought but don't have yet is the :supermod: Deluxe Fan because after I get my PCM back from Magnuson I have to ship it to @Supermodulation along with the throttle body as well, and he is going to ship me my Fans, PCM & throttle body back. I just shipped off the PCM & TCM to Magnuson today and I'm heading out of town for a few days so hopefully it will be back by the time I get back. So anyway let's start with the parts list, then onto the pics.
Supercharger: https://www.summitracing.com/parts/mps-011960031bl
Cam Kit: https://www.texas-speed.com/p-5332-texas-speed-53-vvt-camshaft-package.aspx
-TSP 216/220, .600"/.600", 112 LSA
-PAC/TSP .660" Dual Spring Kit w/ PAC Springs & Titanium Retainers
-Pushrods are TBD
-Crank Bolt/Gasket Kit w/ ARP Bolt #28
-Comp Cams Phaser limiter kit #5456
VVT Cam Bolt: https://www.summitracing.com/parts/nal-12588151
Timing Chain: C5-R Timing Chain ? Katech Performance Online Store
Timing Chain Dampener: https://www.texas-speed.com/p-399-gm-ls2ls3ls7l92l76-timing-chain-dampener.aspx
Rocker Arm Set: https://www.texas-speed.com/p-6069-...steel-roller-rocker-arm-set-w-roller-tip.aspx
Rocker Arm Base: https://www.livernoismotorsports.com/product/LPP821101
Rocker Arm Studs: https://www.summitracing.com/parts/arp-234-7207
Spark Plugs: https://www.summitracing.com/parts/ngk-3690
Plug Wires: https://www.msdperformance.com/prod...pecific_super_conductor_wire_sets/parts/32813
Valve Covers: https://www.summitracing.com/parts/hly-241-112
Valve Cover Gaskets: https://www.summitracing.com/parts/fel-vs50504r1
PCV Valve: https://www.summitracing.com/parts/bck-045-0299
Water Pump: https://www.holley.com/products/cooling/water_pumps/water_pump/parts/22-102
Thermostat: https://www.summitracing.com/parts/lpe-l310155307
Serpentine Conversion Pulley Kit: https://www.summitracing.com/parts/ati-917339
2x Idler Pulley: https://www.summitracing.com/parts/ati-916208
Crankshaft Pin Drill Fixture Kit: https://www.summitracing.com/parts/ATI-918993
Serpentine Belt: http://a.co/3Is4mRY
AC Belt: http://a.co/hAWWEsj
Catch Can: Standard Catch Cans - Elite Engineering
Oil Pump O-Ring: https://www.summitracing.com/parts/fel-72401
Timing Cover Bolts: https://www.summitracing.com/parts/arp-434-1502
Water Pump Bolt Kit: https://www.summitracing.com/parts/arp-434-3202
Coil Bracket Bolt Kit: https://www.summitracing.com/parts/arp-434-2301
Oil Pan Bolt Kit: https://www.summitracing.com/parts/arp-434-6902
Supercharger Pulley Bolts: https://www.summitracing.com/parts/arp-770-1016
Fuel Pump: https://www.summitracing.com/parts/aei-11542/overview/
Fuel Pump Hanger: More Information for ACDELCO MU1885
Fuel Pump Seal: More Information for ACDELCO G41
Fuel Pump Lock Ring: More Information for ACDELCO TR26
Few Tools for the Project:
Pushrod Length Checker: https://www.summitracing.com/parts/cca-7702-1
Trunnion Installation Tool: https://www.summitracing.com/parts/pow-54702-tl
Valve Spring Compressor Tool: https://www.summitracing.com/parts/cca-5462
Ok then on to the ton of pics of these parts..
:emoticonwithoutpics
Supercharger:
Pulley Kit:
Cam Kit Parts:
Rocker Arms & Trunions
Valve Covers
Rocker Arm Pedestal
Water Pump
Fuel Pump
Plug's & Wires
Elite Engineering Catch Can
Bolt's & Other Stuff
Some Tools that I bought that I didn't have.
Damn that was a beautiful update....... LS awesomeness and tons of pics
Best damn post this month....maybe even summer
Ha Thanks, mind you i've been collecting these parts for about ~8 months now so I could have been updating as I went along but figured this is more fun.
Impressive. You don't mess around.
I figure if your gonna do it, do it right. :thumbup:
Yup, I officially hate you now lol.
Looks like it's gonna be badass man!
Damn I'm loving this
How much power are you trying to put down?
That's a nice list of parts you got. That cam kit is priced pretty decent for what you get.
Sent from my Nexus 6P using Tapatalk
Mordis Build Thread - Supercharger & Cam
Wow! I'm kind of jealous rn. I have 3 years with my project, but family got bigger so got to put my priorities straight. in the mean time, I'm subscribing!!
:D lol, yeah im hoping it will burn up some tires.
Thanks bro.
I don't think you ordered enough parts
You're probally right im sure I'll need to get more once i really get going on it.
Power wise im hoping for at least 400 RWHP then ill figure out from there if I want to take it any further. And yeah that TSP kit is a decent setup, one of the factors that kind of expanded my project.
Wow! I'm kind of jealous rn. I have 3 years with my project, but family got bigger so got to put my priorities straight. in the mean time, I'm subscribing ?
I hear ya, family will do that. Thanks for the Sub, hoping to tear into it once i get back in town.
Only 400? Pulley down, spray meth and go 550!
Oh I know thats a possiblity just gotta get a trans that i know will hold up and also install a Truetrac in the rear.
Build a full floater rear
