just a quick couple pics after my recent install:
You're too purple :chuk:They're too purple...
actually in person they are more blue than anything else..They're too purple...
How do you disable the auto light? I hate that thing. :dawg:Intimidator- You going to disable the auto-light sensor? Good choice on the kit, same one I have :355:
Pull out your sensor and unplug it from the harness but do not allow the harness to fall in just yet.How do you disable the auto light? I hate that thing. :dawg:
Thanks RR....I like this site more and more everyday....good knowledge and QUICK response....looks like im going to get it done tonight thanks! :salute:Pull out your sensor and unplug it from the harness but do not allow the harness to fall in just yet.
Get yourself a 680-Ohm resistor (1/2 watt or 1/4 watt, whatever is available) and plug it into the harness -- doesn't matter which lead goes where. Make sure it's pushed as far down as you can get it.
Then just drop the harness into the hole and push the sensor back into its location in the dash and you're done.
With this setup, your DRLs will always be on, even at night.
you know you dont HAVE to disable it right?Intimidator- You going to disable the auto-light sensor? Good choice on the kit, same one I have :355:
