1 - 20 of 24 Posts
hey family i am in need of wisdom from the wise wizards of the v8 world. my dad gave me an LS engine for a project of mine but i can't seem to identify it with what i know. here are some pics.
what i have found from my own investigations is that i believe it's out of a truck due to it's larger sized intake, and from it's three hole-mounted throttle body i believe it's an earlier style LS engine. for the life of me i can't seem to decipher the stampings. these are all the pictures i have of it so if more are needed i'll have to ask my dad to send some since it's still with him. any help would be appreciated.
T
Aluminum or steel block? check on the back It is written 4.8, 5.3 or 6.0. Send a picture of what is stamped on the block.
T
If 243 heads, you have the HO 5.3 which is the gen3 equivalent of the LH8.
The Casting Number for a LS Series Block is located on the rear of the block just below the drive side head. (See Image) However, occasionally the cast number may be located on the Passenger Side. The last 3 or 4 digits of a head's casting number are located on the lower-right side of the head. (See Image)
Block Casting Number
Engine Model
Year Range
12550592
LS1 (5.7L/346ci)
1997
12559846
LS1 (5.7L/346ci)
1998
12559090
LS1 (5.7L/346ci)
1998
12562174
LS1 (5.7L/346ci)
1998
12559846
LS1 (5.7L/346ci)
1998
12560621
LS1 (5.7L/346ci)
1998
1240030
LS1 C5R (5.7L/346ci)
C5R Racing Block
12559378
LS1 (5.7L/346ci)
1999-2000
12561168
LS1/LS6 (5.7L/346ci)
2001
12561166
2001-2004
12568952
LS2 (6.0L/364ci)
2005
12560799
LS2 (6.0L/364ci)
2006-2007
12584724
LS3 (6.2L/376ci)
2008-Present
12598723
LS7 (7.0L/427ci)
2006-Present
12621766
LS9 (6.2L/376ci)
2009-Present
12569513
5.3L Aluminum
2005*
12551358
4.8L/5.3L Cast Iron
1999-2003*
12551364
6.0L Cast Iron
1999-2004
*Year Range Listed is for Known Years only.
Engine Model
Year Range
10212339
LS1 (5.7L/346ci)
1997-1998
12558805
LS1 (5.7L/346ci)
1997-1998
12559852
LS1 (5.7L/346ci)
1999-2001
12564241
LS1 (5.7L/346ci)
2001-2004
12564243
LS6 (5.7L/346ci)
2001-2005
12564243
LS2 (6.0L/364ci)
2005-2007
12600821
LS3 (6.2L/376ci)
2008-Present
12578452
LS7 (7.0L/427ci)
2006-Present
12621771
LS9 (6.2L/376ci)
2009-Present
12559862
1999-2003*
12561706
4.8L/5.3L Cast Iron
2004*
12562317
4.8L/5.3L Cast Iron
2001-2006*
12572317
6.0L Cast Iron
2001-2006*
12572035
6.0L Cast Iron
2001-2006*
Thanks to everyone for the help that's some amazing information right there. I'll try to get my dad to take a look behind it this afternoon and get back with y'all with an update.
Discussion Starter #8
Dad's supposed to go take a look when he gets home. This is the pain of living little over 2 hours from your project. Lol will update when I get information!
Discussion Starter #9
okay here are the pics my dad sent me i hope these help.
I hope these help at least narrow stuff down!
T
Ask your daddy to check the heads casting numbers, written on the top, side of both heads. And voila.
Kind of a rare engine if it's a L33. only available 2005-2007 on 4wd 1500s
Nope. L33 was just a high output version of the LM4. The LM4 is an aluminum block version of the LM7. These are Gen III GM small block engines.
Like tahitian said check the casting numbers on the heads
Discussion Starter #18
Will certainly do thank you all so much for the help. Least now I am in the right direction on where to go. Now to find out just how to fit her into the project lol
The L33 will put out a little more HP and torque....
Discussion Starter #20
That's what i'm getting from what i'm reading. I can hope it's the L33 but even if it's just the LM4 I doubt it'll have a single problem getting this up to speed :D ;)
1 - 20 of 24 Posts
