Here's the background, truck is a 2008 Colorado Z71 4 x 4 with 100,000 miles. I've owned it since new and it's never had a wheel alignment done as it's never shown any adverse tire wear. As a N.E. Ohio truck exposed to harsh winters and road salt its underside is very rusty and has frame issues. After reading tons of negative experiences of owners FEA accounts I'm thinking no shop is going to tackle a full alignment for me any time soon.
Currently the truck needs an inner tie rod boot. I'm not sure how long the boot has been torn but it may have caused problems with that joint. So, if I do an inner and outer tie rod replacement would only the toe adjustment be needed? I'm really trying to avoid the hassle of a shop saying they can't do just a toe correction without the full alignment. I believe my options to be either do it myself or find a shop willing to do just the toe correction. Am I correct that in my situation only the toe adjustment is needed? The truck, unfortunately, doesn't have a lot of miles left in it so I'm looking for the best cheap solution.
