1 - 18 of 18 Posts
Hey guys just a quick question about my new 2.9L 4cyl crew cab
It seems to run warm like almost 3/4 or so is this normal. It only has 600 miles on it now I took it to the dealer and they said its normal is this true?
Thanks see it at SEMA 2007
Not sure about the 2.9, mine's a 2.8 and it never gets above 1/2. :shrug:
Might be because of the break-in period though...wouldn't surprise me.
P
Im running a little over half most of the time, like highway and stuff, but IT IS 100+ in arizona right now.
I ran with the AC on full blast this morning, carrying a load of furniture in the bed, and going uphill at 70-75 and it didn't even get up to halfway once.
When I first got mine it never went further above the 1/4 mark. Then we had a heat wave and it went up to half and stays there now. During the heat wave I was stuck in traffic once and it went up to 3/4.
I've still never seen mine above the 3/8'ths mark. The "normal" spot seems to vary quite a bit from truck to truck.
im willing to bet that all of our trucks run at almost the same temp, just the quality of the thermistors or variable resistors or whatever GM uses in the sensors is whats giving us the inacurate readings...
^ I would agree. I've heard of some people swapping complete gauge clusters and after the swap the needle sits in a different spot as well.
ive never seen mine go past half, usualy hangs a dot over 1/4....
gotta love chevys. i just trust its not over heating.
Mine sits there all the time now :( I took it to the dealer, they said normal too!
GRrr
Its not my gauge, my scan gauge reports high temps, and its not a bad sensor, as you open the hood, you can tell!
All the trucks I've ran the scanner on would run between 180 and 195. You could have one truck runing at 181 and the guage will be a half, while another will be at 193 and the guage will be at a quarter.
Discussion Starter #18
Thanks for all the imput, I took it back to dealer and they played with it now sits @ about 1/2 or 1 click above. I am just watching closely to make sure no issues before I take it back again.
SEMA 2007 project so hopefully nothing major before I cut it up soon
1 - 18 of 18 Posts
