So I got everything installed yesterday. I've got 2" Belltech drop balljoints, 2" Belltech blocks, JTR crossmember and Monroe MA759. It took me 11 hours and I'm feeling it today, but I did it all by myself. So if your wanting to do the work but don't have an extra hand, it can be done. The only issue I really ran into was with the lowering balljoints. I don't know if my lower control arms had been replaced or are OEM, but I had problems with the spacer that fits inside the lower control arm. There was a support rib inside that prevented the spacer from going all the way in to line up with the holes. Also the spacer was slightly thicker that the balljoint it replaced. The first side I put it was wedged pretty good and I didn't realize the rib in the back would hit before it was too late. So it went in far enough that I couldn't get it back out. So I had to beat it into submission to get it in all the way. The other side I used my grinder with a flapper wheel to take off just a little bit of the thickness no I could move it in and out without too much hassle. Then I had to notch the back side of the spacer to swallow that rib that was in there. It was a major pain on that first one, and with all the reading I've done about this setup I hadn't seen anyone that had those troubles. So if you're looking to do this its worth checking.
Here's that rib that I was hitting.
And here's the finished product. I currently have 30PSI in the rear shocks. I'll probably play around with it a little bit to find the sweet spot of where i like it.
And here's a before picture to get an idea.
If you have any questions about the install feel free to ask.
Victor
Victor
