Okay guys, I've been browsing forums all day long and I can't seem to find an answer to my problem.
2009 Canyon 2.9L 4cy Manual
I started getting the ABS and Stabilty Trak light a few weeks ago. I would turn the truck off, turn it back on, and it would go away. It didn't bother me until this morning. I was driving to work and after driving for about 30 mins, all of my gauges shut off and my radio.
I still have all exteror lights working, as well as the dome light and cigarret lighter. Truck intermittently starts. When it doesn't start, I will turn the key. No crank or clicks, just solid check engine light.
I disabled Passlock over a year ago. I have HIDs that are wired directly to the battery via a wiring harness (still work and no flickering). I have a pioneer head unit. All modifications to the truck were done over two years ago and this problem is basically all the sudden.
Also, I can sit in the truck with no key in the ignition and the truck is off. I can actually turn the AC on. The fan will run, but the compressor won't kick on to cool the air.
I replaced the battery and the alternator is putting out 13.7v. I've checked the fuses and everything checks out good. Also, I want to add that sometimes when it does start, everything will work fine for about 2 mins and then I lose gauges and radio so this leads me to believe its not a fuse since it still works half the time.
The dealer is telling me ignition switch and possibly pcm or bcm. Sounds to me like they're just throwing parts at it to try to fix the problem. I want to avoid the dealership as muich as possible.
What do you guys think? PCM/BCM??
