1 - 11 of 11 Posts
· Premium Member
My 2011 has a three pin connector. An additional ground wire (blk/wh) was added for the operation of the map lights. That ground goes to G300 which is under the carpet beneath the Driver's seat. The other two wires are the same, in that they originate at the BCM.
Discussion Starter · #11 ·
There are three wires on the 09+ dome light circuit. The white wire is negative switched, the orange wire is a 12+ constant and the black wire is a ground.
I'm curious if the plugs are the same.
No plugs aren't the same. The original 2 wire has a yellow and orange wire. So what wires should go together? I'm guessing I need to run a separate wire to the orange wire.
Sent from crappy AutoGuide.com Free App
1 - 11 of 11 Posts
