41 - 60 of 62 Posts
The way you notched the crossmember for the lower link rod end , if you made the mount longer would that not been better or would it cause other issues? Looks good you've made a lot of progress!
Sent from my SM-G960U using Tapatalk
2005 Colorado
Discussion Starter · #44 · (Edited)
I wanted the rod ends tucked up as high has I could go with the crossmember at I could get… the Johnny joints are quite large on the o.d. If the crossmember was longer it would of pushed it closer to the t case and the yoke. The arms are 38 inches long which is plenty long… my Jeep TJ has a long arm kit on it and they are only 32 inches long.
Sent from my iPhone using Tapatalk Pro
2005 Colorado
Discussion Starter · #45 ·
Mocked up the steering box today.. I wasn’t to thrilled about removing some sheet metal to make it fit but I’ll make it look good when it’s all done.
Y
2005 Colorado
Discussion Starter · #50 ·
Haven’t had much time to post but here is a little update. Steering is all mocked up and track bar is fabricated (kinda). Not sure of the bends that will be needed but length wise it’s mocked up.
Your fab skills are excellent. I enjoy seeing all your updates
I’d really love to have you around my neck of the woods to help me with my SAS. I’m hopeful to start mine this summer after the camping season ends.
2005 Colorado
Discussion Starter · #52 ·
Thank you. Well I try to document everything that way it gives people confidents and a direction to start theirs. All my Jeep builds are very detailed on the build threads.
2005 Colorado
Discussion Starter · #55 ·
Installed the Motobilt Dana 60 diff cover to make sure it clears the track bar bracket. Also mocking up the Jeep Jk air bumps that mount in the Jeep spring mounts on using.
Do you have a measurement of how wide the frame is from outside to outside? With my narrower axles I may have to rethink my coil spring mounting points on the frame.
2005 Colorado
Discussion Starter · #57 ·
It should be about 33-34 inches. I can check tomorrow for a measurement.
Thanks, I was thinking about that. I have measured it at other spots and it is wider, but measuring right where the axle would sit is kind of hard on a daily that you have to use until you get ready to do the swap.
2005 Colorado
Discussion Starter · #59 ·
It is 32 inches on the outside of the frame.
41 - 60 of 62 Posts
