Check the fuse block under the hood and see if the CNSTR VENT fuse is good.
Hey there,I threw the Evap circuit code several weeks ago. I used my extended protection plan to get it fixed at a dealership. They replaced the solenoid and hose. Then the code came back the next day. I got a new gas cap and installed it Monday. Code came back on last night. What else could it be?
Was there some reason that you didn't take it back to the Dealer and ask them why the DTC came back after they "corrected" the problem? Part of their troubleshooting should have included the wiring, which is about all there is, besides the valve. Maybe they screwed up the valve installation, because the newer replacement valves require a "jumper" cable to connect with the older installations. What parts/part numbers did you get charged for?I threw the Evap circuit code several weeks ago. I used my extended protection plan to get it fixed at a dealership. They replaced the solenoid and hose. Then the code came back the next day. I got a new gas cap and installed it Monday. Code came back on last night. What else could it be?
Mostly time. I've been been busy the last few weeks and don't want to go without the truck if it's something simple I can fix. I also prefer to do things myself so I can learn about it. I was charged for the following:Was there some reason that you didn't take it back to the Dealer and ask them why the DTC came back after they "corrected" the problem? Part of their troubleshooting should have included the wiring, which is about all there is, besides the valve. Maybe they screwed up the valve installation, because the newer replacement valves require a "jumper" cable to connect with the older installations. What parts/part numbers did you get charged for?
Note: Gas cap won't affect a DTC P0449.
The part number 12597567, that he was charged for, is the Purge Valve, so hopefully it has been replaced. Even though it has nothing to do with DTC P0449.
Yeah, I was thinking solenoid for some reason, but after checking the invoice I was mistaken. It's been a long day.He said solenoid (meaning the valve and hose connected to the canister) Maybe he doesn't know exactly what was changed??
Understandable, don't sweat it. I call it the same, they call it a hose. Again this is the reason why this site was created. At this point all I could think of is that they did not replace one of the components they said they replaced or it's defective. The purge valve is where the picture saids above and the canister "hose" is behind the spare tire. Can you verify that these parts look new?Yeah, I was thinking solenoid for some reason, but after checking the invoice I was mistaken. It's been a long day.
Here's something that you can check. The canister, that the vent solenoid valve is attached to, is located just above the forward edge of the spare tire. With a mirror and flashlight, check the wiring connector to the vent solenoid. You need to determine that the correct connector is mated to your solenoid valve. On older trucks, such as yours, the connector/receptacle for the solenoid was oval shaped. GM discontinued the valves in that configuration and the newer valves have a square shape connector. It appears that the Dealer installed one of the newer configuration valves, and if so, they needed to install a "jumper" cable to properly connect the harness. You don't indicate that you were charged for one (PN 12597567) so it's possible that the mechanic just "jammed" the oval connector in the square hole.Mostly time. I've been been busy the last few weeks and don't want to go without the truck if it's something simple I can fix. I also prefer to do things myself so I can learn about it. I was charged for the following:
1 12597567 - (s) Valve
1 12579283 - (s) Bracket
1 20907779 - (s) hose
