Vehicle Specific Products
DISC BRAKE KIT FRONT - 3 PISTON TRI-POWER WITH 14IN ROTOR
SKU: A117-12
Front Kit Part Number:
A117-12
- All hardware included.
- Calipers come with Clear Anodizefinish. Optional polishing or powder-coating available.
- Includes Tri-Power 3-Piston aluminum calipers.
- Includes high performance pads.
- Includes Turbo slotted rotors with Xtra Life plating.
If made in the USA is important to you, take a look at the SSBC Performance brakes front brake kits. Our Tri-Power 3 Piston Front Brake Kits, made from Billet aluminum, are complete with all the necessary components for installation. Coated with a clear anodize for maximum corrosion resistance both internally and externally. Assembled with stainless steel pistons for maximum longevity in any condition. With this caliper you will enjoy maximum braking potential in a sleek compact design to fit most popular wheels.* Slotted and plated rotors are standard in most kits, but the upgrade to Big Bite Cross Drilled rotors is available. As with every SSBC kit your replacement pads are available at any local parts store.
DISC BRAKE KIT REAR - 1 (SINGLE) PISTON SPORT R1 PLUS WITH 12.8IN ROTOR
Rear Kit Part Number:
A117-14
SKU: A117-14
- Includes braided stainless flex lines.
- Includes Sport R1 Single-Piston aluminum calipers.
All hardware is included in the SSBC Performance Brake Systems single piston rear disc brake conversions available in a wide of variety of rotor diameters ranging from 10.5 to 12.8 and piston sizes from 45mm to 54mm. The caliper includes a built-in parking brake and easy bolt on installation. The kits work on most factory parking brake cables. Optional polishing or powder-coating is available in most applications. SSBC boasts over 34 years of manufacturing and engineering the finest disc brake products. Our highly trained technical staff set the highest quality control standards and possess up to the minute design, engineering and testing capabilities. Our commitment to our customers doesnt stop there. The SSBC staff works diligently each year, developing and perfecting new products to meet your braking needs. Check out the caliper & rotor spec's page to see whats included in your kit.
