1 - 7 of 7 Posts
the power window on the passenger side is sticking or something, it works most of the time but every once in a while it sticks. i can hear it clicking when i push the button but nothing and then bam it works. so whats going on with this?
HO IT
I have the same thing happen with my driver's side window sometimes, it started conveniently right after my warranty was up so I just let it go as long as it works.
Take off the door panel and make sure the motor is still bolted tight. I had a problem a month ago where my window would make clicking noises and sometimes bangs, turned out to be my window motor. One bolt had come completely out and two more were very loose.
you may want to lube up the channels while youre doing that.
...slam the door til it works. Don't laugh it works.
:true:
Sometimes the motors freeze... if slamming the door doesn't work, proceed with taking out the motor completely and lighting tapping it with a hammer to free it up. If that doesn't solve your problem, it's time for a new one.
1 - 7 of 7 Posts
