1 - 5 of 5 Posts
Hey looking to replace my shattered front passenger side window. Gonna head to the junkyard tomorrow to pickup a window. Can someone point me in the right direction on how to remove and replace it? And what tools will be needed in the process? Thanks
Front Side Door Window Replacement
Removal Procedure
  1. Position the front door window approximately halfway down.
  2. Remove the front door trim panel.
  3. Remove the front door water deflector.
  4. Remove the front door outer belt sealing strip.
  5. Remove the bolts retaining the front door window to the window regulator.
  6. Lift the window off of the window regulator.
  7. Rotate the rear of the window upwards, disengaging the window from the window run channel.
  8. Remove the window from between the inner and outer door panels.
Installation Procedure
  1. Install the front door window into the front door between the inner and outer door panels.
  2. Rotate the rear of the window down, positioning the window into the window run channels.
  3. Lower the window down onto the window regulator.
  4. Install the bolts retaining the front door window to the window regulator. Tighten the front window bolts to 9 N·m (80 lb in).
  5. Install the front door outer belt sealing strip.
  6. Install the front door water deflector.
  7. Install the front door trim panel.
1 - 5 of 5 Posts
