2006 Chevy Colorado
2.8 L gas
Automatic
Hello everyone, I'm Josh btw, new to the community... I read what you were saying in the 355forum about passlock and grounds....man I am having a terrible time with my Colorado. I have replaced throttle body,fuel pump,ignition switch,housing, cylinder,bcm,ecu tuned and (supposedly) erase vats-passlock by pctuners of nc, cluster, crankshaft pos. sensor, camshaft pos. sensor, VVT solenoid, starter, alternator, battery is a fairly new red top optima, the list continues with buying crap for this truck and I've been grounded for a month and a half with a no start...it turns over but doesn't fire....I've checked grounds and rechecked and even put more grounds on to the frame.....replaced all coil packs, spark plugs, o2 sensors, purge valve solenoid,map sensor, fuel pressure sensor does it have to go to dealership it says crank angle shaft relearn necessary now since I changed bcm, I think my old one was bad and not communicating because I changed that like a month ago and never got the code error......what should I do?
2.8 L gas
Automatic
