41 - 60 of 99 Posts
Sub-model: 2007 Z71 LT 4x4
Tire Size: 35x12.5x15
Rim Size: 15x8
Wheel Spacers: None
Lift Height: 8 (or so) Inch lift 46" ground to fender
Lift Components: 4" Skyjacker, 3" Body lift, 2" shackles, 1 1/2 Tortion bar lift.
Flares/Fenders: Z71
Trimming Requirements: cut body mount & cut front plastic bumper
Any Rubbing: No
Other Important Details: None
Sub-model /z85 4x4
Tire Size /33x12.50
Rim Size /15x8 4.75 backspace
Lift Height (hub to fender measurement)
Lift Components/ suspension maxx diff drop, ball joint flip.75", tuff country keys 3", Tuff country 3" AAL and 2"shackles body lift 1.5"
Total amount: 5.5" lift
Trimming or cutting/ took off black valance, notched gas tank crossmember.
Any Rubbing (Yes body mount. Never needed to cut. Didn't rub bad enough.
Pictures :
Sub-model: Z 71 2wd
Tire Size: 32-11.50-15
Rim Size: 15x8 Summit Racing Black 8's, 3.75" back spacing
Wheel Spacers: No
Lift Height:3 inch, 23.5 front, 23 rear (center of hub to fender lip)
Lift Components: Suspension Maxx keys, shackles, Ball Joint spacer and rear shock extenders.
Flares/Fenders: Z 71
Trimming Requirements: Slight trimming at rear of front fender to the flare and inner liner
Any Rubbing: Slight rubbing in a turn in an off camber position
Pictures:
Fred Savage
  • Sub-model: z85, 3.7L auto
  • Tire Size: 285/70/17 (32.8" x 11.5") Firestone Destination A/T
  • Rim: Vision Warriors 17x8.5, 5.7" BS
  • Wheel Spacers: 1"
  • Lift Height (hub to fender): 24"
  • Lift Components: CST 5" Spindles, CST AAL, Suspension Max adjustable shackles (middle setting), Rancho RS5325 Rear Shocks
  • Flares/Fenders: Z71's to be added
  • Trimming Requirements: lower valence/bumper lip removed, lower bumper trimmed
  • Any Rubbing: rubbed on front mud guards, had to remove them
  • Hub studs were cut for rims to mount flush on spacers
  • Extended front brake lines needed (I used the ones supplied by CST)
1) Sub-model: 2005 Colorado Ext cab. Z71 4x4 3.5L Auto
2) Tire Size: 31x10.50R15 BFgoodrich Radial Long Trail's (for now)
3) Rim Size: 15 Diameter/7" Width/I think 6.5" BS (stock z71 rims)(for now)
4) Wheel Spacers: None
5) Lift Height: Didn't measure but Front: 2.5" higher than stock/Rear: 2.5" higher
6) Lift Components: 2.5" Front TB Crank with new Re-indexed keys/2.5" New Rear Shackles. (Additional 1" Front TB Crank/2.5" Skyjacker AAL Coming soon)
7) Flares/Fenders: Stock Z71 Flares
8) Trimming Requirements: None required, but I did remove lower valence for looks.
9) Any Rubbing: None at all
10) New Skyjacker Hydro 7000 shocks front/back
11) Since these pics were taken I've removed the stickers on the back two doors, de-badged the truck, blacked out the brakelights and fliped the 3rd brakelight.
Sub-model (z71, z85, etc) 2008 GMC Canyon z85 2wd
Tire Size (diameter, width) 285/75/16
Rim Size (diameter, width, backspace)16x9 Moto Metal MO951
Wheel Spacers: no
Lift Components (i.e: 4" skyjacker, 3" body lift, 3" crank, etc) 5in CST spindle, 2in Smaxx shackle and 2.5in ebay add-a-leaf. skyjacker rear shocks. Smaxx 1.5in body lift.
Flares/Fenders (i.e: fiberglass fenders, Z71 flares, etc):none now, Fiberglass fenders in the future
Trimming Requirements (valence, body mount, etc). Front bumper plastic trimmed about an inch off. Front body mount (behind front tire) needs trimmed back a bit.
Any Rubbing (Yes / No, Where / When) On the front bumper plastic still when turning sharp on an incline or while flexing too much. Very little rubbing on body mount under same conditions with wheels turned all the way to the lock.
Sub-model: 2011 Crew Cab Z85 2WD
Tire Size: 245/75R16
Rim Size: Z85 Stock wheels
Wheel Spacers: None
Lift Height: 2.5" front 1.5" back
Lift Components: Ready Lift SST Kit (Strut extensions on front, shackles in the back)
Flares/Fenders: None
Any Rubbing:With sway bar at full lock
Build Thread Link: N/A yet.
Other Important Details: No torsion key crank.
Pictures:
Sub-model: 2004 Ext Cab Z85 4x4
Tire Size: 31x10.50 R15
Rim Size: 15x8 American Racing Baja. 5.25" Backspacing and +19mm Offset
Wheel Spacers: None
Lift Height: 2" front 1.5" back
Lift Components: 2" TB Crank Front, 1.5" Shackles Rear
Flares/Fenders: Stock Z85 Flares
Any Rubbing: None
Build Thread Link: None
Sub-model: 2006 GMC Canyon Offroad (z71)
Tire Size: 33x10.50x15
Rim Size: 15x8 3.75 BS
Wheel Spacers: N/A
Lift Height: 24.5" Front, 24" Rear
Lift Components: 3.5" Crank, SMAXX TBs and Diff Drop, 4" Skyjacker AAL, Skyjacker Hydro 7ks
Flares/Fenders: Z71 flares
Trimming Requirements: Removed front mudflaps, removed bumper valence, front bumper trim
Any Rubbing: Sway bar, rear cab mount/wheel wells
Build Thread: N/A
Other Important Details: Wheels will clear with less crank
Sub-model (z71, z85, etc) 05 z71 4x4
Tire Size (diameter, width) 33x12.50x15 thunderer M/T
Rim Size (diameter, width, backspace) stock z71
Wheel Spacers 1.25
Lift Height (hub to fender measurement) 26 1/2
Lift Components (i.e: 4" skyjacker, 3" body lift, 3" crank, etc) 3" tb crank, 2" add a leaf, 1" body lift
Flares/Fenders (i.e: fiberglass fenders, Z71 flares, etc) z71 flares
Trimming Requirements (valence, body mount, etc) none
Any Rubbing (Yes / No, Where / When) none
Pictures (If possible: side profile, other related tight clearances while turning / flexing THUMBNAILS PREFERRED!)
Build Thread Link
RIP Forrest
Sub-model - Z71 2wd
Tire Size - 35x12.50
Rim Size - 20 x 9
Lift Height - 48" ground to fender
Lift Components - 4" skyjacker, 3" body lift, few inches of crank in front, soa and helper bags in rear
Flares/Fenders - Z71
Trimming Requirements - no valence, bumper cut
Any Rubbing - a lil on body mount
Sub-model (z71, z85, etc) 2011 z85 4x4
Tire Size (diameter, width) 265/75/16 Hercules A/T
Rim Size (diameter, width, backspace) stock z85 (16 inch)
Lift Height (hub to fender measurement) 23.5
Lift Components (i.e: 4" skyjacker, 3" body lift, 3" crank, etc) 3" tb crank on SMaxx Keys, BJ Flip.
Flares/Fenders (i.e: fiberglass fenders, Z71 flares, etc) stock
Any Rubbing (Yes / No, Where / When) A little at full turn.
Sub-model (z71, z85, etc): Z85 4x4
Tire Size (diameter, width):255/75/71 (32.in)
Rim Size (diameter, width, backspace):17x8.5 5.00BS
Wheel Spacers: .25in
Lift Height (hub to fender measurement) n/a
Lift Components (i.e: 4" skyjacker, 3" body lift, 3" crank, etc): 4in rancho, zone 1.5in BL, AAL, 1 in TB crank
Flares/Fenders (i.e: fiberglass fenders, Z71 flares, etc): little Z85
Trimming Requirements (valence, body mount, etc):No but I never ran a stock front bumper
Any Rubbing (Yes / No, Where / When): none
Build Thread Link
Other Important Details: Very close to rubbing tire on top of spindle
Nipple
Discussion Starter · #55 · (Edited)
NOTICE: To view a spreadsheet of the given data visit the link below.
>>>Lifted Chart<<<
Please continue to provide data by posting up in this thread then we will add it to the spreadsheet.
Stay tuned for the lowered chart!
Link also added to the OP
>>>Lifted Chart<<<
I do not see all the data that I see in the thread, but I guess you condensed some tire sizes and such into one?
Nipple
Discussion Starter · #58 ·
Lifted chart is legit! Nicely done
Not all lifted data is entered in yet. The current chart came from a formerly existing one that I had not updated in some time. I will be adding the remaining data when I get the chance here soon.
Thank you both for your comments and concerns, but in the future, please PM me instead of posting here as to keep clutter out of the data.
Thanks again,
Levi
Sub-model: 2008 Z85 LT 4x4
Tire Size: 295/75R16
Rim Size: 16x8 4.5" backspace
Wheel Spacers: 1.5" front
Lift Height: 6.5"
Lift Components Front: 4" Skyjacker, 1" Body lift, 1" lift shackle, 1.5" TB crank,
Michigan Metal works uniball UCA...
Flares/Fenders: Z71
Trimming Requirements: bumper mount, chassis and fender trim.
Any Rubbing: not really.. only when i bottom out.
I saw nothing in the chart about this size so figured I'd post up.
Submodel: 2005 Canyon SLE 4x4 z71
Tire Size: 33x10.50r15 BfGoodrich All-Terrains
Rims: oem z71 rims 15x7.5
Spacers: none
Lift height: 3.5 inches
Components: zone 2 inch suspension lift, zone 1.5 inch body lift
Flares: z71 flares
Trimming: had to remove front mudflaps and front lower bumper valence
Rubbing: they lightly hit the sway bar under the right circumstances
Pictures:
41 - 60 of 99 Posts
