81 - 99 of 99 Posts
Thanks for the reply. I have a Z85 4x4 w/ runs with TBs so I'm guessing (more like hoping...) that I would just crank the TBs maybe an inch or 2" and then mount the tires to see if it clears.....at least that's my plan.
The problem that is holding me is that if I pull the trigger and buy them and then don't work it's going to be a pain to return these things, especially if bough on the web....
You should be fine on 31's if you crank it about an inch and a half, I am on 32,s on my Z71, cranked about 2.5 inches, give or take. I rubbed the rear of the front wheel wells but a little trimming fixed that.
Toyo Extenza blown out 235/75R/15 to fit my aluminum alloy 10" in wide wheels
All stock suspension AEM cold air intake, flowmaster super 44 exhaust. Eventually getting a tune up and better brakes.
Going to lift with 3in spacers on some 31's here soon I hope.
2x4
Might also get a PTB
Tinted taillights
Interior red LED sltrips.
Aftermarket radio and two 12" kickers with a PA.
Sub-model: z85 4x4
Tire Size: 31x10.5 R15
Rim Size: stock z85 wheels 15x6.5
Wheel Spacers: 1/4"
Lift Height: 23.75" hub to fender front, and 24.25" rear
Lift Components: 2.75" torsion key Crank, 2" lift shackles...and 1.5" rear shock extenders, bj flip with suspension maxx spacer
Flares/Fenders: zq8 flares
Trimming Requirements: none
Any Rubbing: None
2006 Chevrolet Colorado
Z71
285/75/16
Rim size: AR172 Baja 16x8 0 offset 4.5in Backspace
Wheel Spacers: None
Lift Components: Rough Country leveling kit(previous owner installed)
ProComp 13120 Add A Leaf
Suspension Maxx Ball Joint Flip and 1.5in Body Lift
3in Torsion Crank
Flares/Fenders: Z71 flares
Trimming Requirements: Removed lower bumper valence and need to trim
Any Rubbing: Yes. Where: Front Bumper. When: Max Lock and Flex
Z71
285/75/16
Wheel Spacers: None
3in Torsion Crank
I have almost the exact same setup as you minus the add a leaf and BJ flip.
Im now curious if I could clear 285/75/16 if I ran a wheel with a negative offset.
For how cheap it is to get the add a leaf and ball joint flip, I would just get those first. $42 for the flip and $37 for the add a leaf. We'll worth it too.
I guess I'll add mine to this now.
Sub-model: z85 4x4
Tire Size:285/75/16
Rim Size: 16x8 -12 offset/4"BS
Wheel Spacers: None
Lift Height: 26.5" front 27" rear
Lift Components:2.5" Rough Country lift/level kit; bj flip; Tuff Country add a leaf; 1.5 Suspension Maxx bodylift
Flares/Fenders: Bushwacker Extended flares
Trimming Requirements: I didn't have to trim anything, but I also don't have the plastic valence on my truck anymore.
Any Rubbing: None on the road, fully flexed and at lock the front rubs the body mount. Not a lot but enough, I'll be trimming and re welding my body mount.
2007 z71 2wd QC
Sub-model: z71 2wd
Tire Size: 32x11.5 R15 BFG KO2s
Rim Size: stock z71 chrome wheels 15x7
Lift Height: 23.5" hub to fender front, and 24" rear
Lift Components: 2.5" re indexed torsion keys, 2" lift shackles, Rancho 5100 shocks in all 4 cornets & ball joint flip/spacer from suspension maxx
Flares/Fenders: z71 OEM textured black flares
Any Rubbing: None after alignment (I had slight rub on the sway bar during inital drive before alignment)
My Chevy Colorado / GMC Canyon lifted 10.5" inches on 35" inch tires 20" inch wheels
4" inch suspension lift kit ( Tuff Country 14045KN )
3.5" torsion bar crank on adjustable Suspension Maxx torsion keys
3" inch body lift kit by Performance Accessories
35x12.50R20 Gladiator QR900 Tires
20x10 Dropstars 645B with -19 offset
Half inch longer aftermarket Uni-ball joint upper control arms made by Larry Harrell IV
Steel bumpers made by Tactical Armor Group
Magnum RT side steps
PSI Pocket Style Fender Flares
etc....
Sub-model (z71, z85, etc) - Z71
Tire Size (diameter, width) - 285/70/17
Rim Size (diameter, width, backspace) - 17x9 -12 offset, 4.53 bs
Wheel Spacers - No
Lift Height (hub to fender measurement) 24.5"
Lift Components (i.e: 4" skyjacker, 3" body lift, 3" crank, etc) - 4" Rancho kit
Flares/Fenders (i.e: fiberglass fenders, Z71 flares, etc) - Z71 flares
Trimming Requirements (valence, body mount, etc) - Front bumper plastic, remove valence, trim passenger side(No driver, idk) fender metal/wheel liner plastic
Any Rubbing (Yes / No, Where / When) - None
No suspension modes, all stock.
No rubbing anywhere.
Wheels, Pro Comp, 51-6883, 16x8, 6-lug, 5.5-bolt-pattern, -6-offset, 4.25-bs, 4.25/108mm-bore,
https://www.procompusa.com/wheels-p...lc=PCW&pqq=2336-1558-1551&pqa=13689-8275-8057
Tires, Cooper AT3 255/70r16, 30 inches x 10 inches,
and it fits in the spare location under the bed!
https://www.willtheyfit.com/index.p...5&aspect2=70&wheel_size=16&wheel_width=8&offs
et2=-6
Z85 suspension
4wd
l5 engine 3.5L, L52 GAS, 5CYL, 3.5L, MFI, L5, ALUM, DOHC, GM
Automatic Transmission, M30 AUTO 4 SPD HMD 4L60-E ELECTRONIC
rear differential, GU6 3.42, G80 limited slip,
- SIZE -------- INCH ---- METRIC -------------------------------
235/75r15 - 28.8 9.3 - 733x235 -
245/75r15 - 29.4 9.7 - 748x245 - No Such Tire Exists
255/70r15 - 29.1 10.2 - 738x255 -
30x9.5r15 - 29.5 9.6 - 749x241 -
245/70r16 - 29.5 9.8 - 749x245 - 16 inch wheel
255/70r16 - 30.0 10.0 - 763x255 - 16 inch wheel
245/75r16 - 30.4 9.6 - 774x245 - 16 inch wheel
265/70r16 - 30.6 10.7 - 777x265 - 16 inch wheel
265/75r15 - 30.7 10.4 - 779x265 -
31x10.5r15 - 31.0 10.5 - 787x267 -
265/75r16 - 31.6 10.4 - 804x265 - 16 inch wheel
285/75r16 - 32.8 11.2 - 834x285 - 16 inch wheel
6x5.5 bolt pattern^^
Thank you, post has been edited.
Sub-model 2009 Z71 V8
Tire Size 265/70R17
Rim Size 17x7 Stock wheels
Lift Height 23.5"-23.75" Hub to Fender
Lift Components 2.25" crank, Ball joint flip w/ small spacer
Flares/Fenders Stock Z71 Flares
Trimming Requirements None
Any Rubbing None
Pictures
Sub-model: z85 4x4
Wheel Spacers: 1/4"
Any Rubbing: None
Hey what grill guard you running? and where can i get one? I like that...
Wheels and Tires (Very obvious which is which in pictures)
16x8.5" 18mm offset MB Chaos 6 w/ 265/75R16 BFGoodrich Mud Terrain KM2's
18x9" 25mm offset KC Addict w/ 285/60R18 Nitto Terra Grapplers
Suspension/Drivetrain
Readylift Hummer H3 Torsion Keys (2.5" crank)
SuspensionMaxx Lift Shackles (2")
Upper Ball Joint Flip
Thicker CV Boots (I'm not willing to lower an aluminum diff)
I've also done some very discreet fender trimming. I can run my KM2's (~32x10.5" equivalent) anywhere, with or without my swaybar connected and not rub. I can run my Terra Grapplers (~32x11.5" equivalent) with no rub on the street with the swaybar connected, though they'll very slightly graze the rear of the fender while wheeling (not even hard enough to make me remotely concerned).
Edit: Cab mount and swaybar clearance with the 285/60R18 Terra Grapplers on level ground (suspension not articulated).
I like this grill guard, where can I get one?
81 - 99 of 99 Posts
