1 - 20 of 255 Posts
Currently, I have 4 Kicker Comp VR 12's and 5,500 watts running to it. I have a 5 cubic foot box built by mc, who used to be a decibel drag race judge and says that it's over 150 db. I will post pictures soon, but I'm curious as to see what everyone else has.
:high5:
Ok I have nothing special... just a dual in-dash touch screen 7" tv/dvd, 2 shallow mount rockford fosgate 10's & Phoenix gold tantrum 1200.1 mono amp and a box built by ChvyZ71 for under my back seat.
:high5:
5,500 watts running 4 kicker comp 12's? 400 watt rms 800 watt max how are you not blowing those lol.
Gain control. ;)
I tuned his amp so that it's giving the subs enough to be loud as holy hell but not bottom out.
I kid you not though...I had 2 Alpine Type R's with 2200 watts running to them in my TransAm. I won several db drag competitions and ultimately hit within the 150-152 range on each spl meter. His system is at least that, probably a db more...:ugh:
It hurts. :lol:
For a non-professional (non sponsored) it's probably one of the loudest systems I've heard.
Oh, and, here's my setup:
1 JVC indash touch screen
2 Alpine Type S 6.5's
1 MTX 2 channel
1 XA-1500D
1 Orion 12
Custom built box (me)
I'll post piks after I get some more sleep, we were all up until 5 drinking. :kiki:
EDIT: Dammit, I can't sleep. :lol:
Here are some pics of my box, the dimensions are 12" deep by 12 1/8" tall by 41" wide. I covered it in grey vinyl that matches the interior pretty close and then I painted the sides with a gloss black for an industrial look. I added a spacer plate to the front and cut the edges at a 45 degree angle; it also received vinyl and I painted the exposed edges black.
one 10" MTX thunder 5500 dvc in a custom built box(by me),MTX 2301 D,MB Quart components in doors with an alpine CDA-9885 runnin it total about 375-400 watts Rms. not alot but loud as hell in a reg cab.
That's a good setup, Alpine is one of my favorite head unit makers.
i have a pioneer premier cd player, rockford fosgate 300w amp, and rockford fosgate 10"p3, need more money to do the rest of the system
I got 4 MA Audio 1200XL's 1 MA audio M689I 800 watt amp and 1 M700XE 1000 watt amp, 2 Farad digital power acoustik cap, kenwood 3ways in the doors and the major low blow stock head unit lol i know i know im saving for the 7 inch double din by kenwood cant remember the model off hand.
MC what wattage amps do you suggest for my 12's cause im gonna be getting two new amps just dont know which model Ma to buy. It will prob be decided on what wattage you think i should run...
-Pioneer AVIC-D3
-Alpine Type R components
-Alpine Type S coaxials
-Rockford Fosgate 4-channel amp
-JL W1 10" in JL angled truck box
-Alpine mono-channel amp
-Custom amp box
-Monster Cable wiring
Does it have to be MA?
Also, I'd need to know what ohm your subs are, whether or not they're dual voice coil, etc. :)
If you're running dual 2 ohm subs, you can wire it so that the amp will see a 1 ohm load or a 4 ohm load. If you're running dual 4 ohm subs you can make the amp see a 2 ohm or 8 ohm load. There are other options, but those are the only ones that you'd really want to explore when it comes to sub amps.
Whatever you're running though, this amp appears to meet all your wattage needs. It may be a little overkill, but with the right tuning, it'll meet your expectations.
http://www.maaudio.com/product.jhtm?id=7&cid=12
HK10KA
Extreme Competition Amplifier
  • RMS / MAX Power Output @14.1V DC
  • 2500W RMS / 3500W MAX @ 4 Ohm Mono
  • 4000W RMS / 6000W MAX @ 2 Ohm Mono
  • 5000W RMS / 7000W MAX @ 1 Ohm Mono
  • RMS / MAX Power Output @17.5v DC
  • 3500W RMS / 5000W MAX @ 4 Ohm Mono
  • 6000W RMS / 8000W MAX @ 2 Ohm Mono
  • 7000W RMS / 10,000W MAX @ 1 Ohm Mono
  • Dimensions (H x W x L)
  • 2.71" x 12.4" x 29"
yeah man i like having all my equipment matching to an extent, that amp is mad expensive lol 2grand on some sites i got dual 4 ohm subs, was kinda hoping to run two amps as well what about these?
RMS Power @ 14.4V: 750W @ 4 Ohm, 1000W @ 2 Ohm, 1500W @ 1 Ohm
RMS Power @ 17.0V: [email protected] 4 Ohm, [email protected] 2 Ohm, 1800W @ 1 Ohm
Fuse Rating: 40A x 4
Dimensions (W x H x D) 12.4" x 2.71" x 14.29"
Temperature, Voltage & Output Level LCD Display
Thermal, Short & Overload Protection Circuitry
Platinum Plated Screw Type RCA Jacks
Double Sided Black Epoxy PCB Board
Platinum Plated Block Terminals
Fully Unregulated Power Supply
Stainless Steel Finish Heat sink
Quiet Fan Cooling System
Remote Gain Control
Full Mosfet Circuitry
Frequency Response: 10Hz - 350Hz
24dB Low Pass Filter: 50Hz - 350Hz
24dB Subsonic Filter: 15Hz - 50Hz
Variable 0 - 18dB Bass Boost Control at 45Hz
RCA Input Sensitivity: 0.2 - 8V
Low level Input Impedance: 22K Ohms
Damping Factor: 200 @ 4 Ohm
1 Ohm Mono Stable
Yeah, if you're running two, those should cover you nicely. :)
You're covered for caps right? 1 farad for every 1K watts, above 3K watts, you want 1.5
i have this under my back seat in my cc. enough bump to even out the sound, i'm not tryin to bump hard
4- Kicker 10L5
2- Kicker ZX1000.1
1- Kicker Zx650.4
1 set -Kicker 6" SS mids in front door
1 set -Kicker 6.5" RS mids in rear doors
2- Stinger batteries plus stock battery
Kenwood DNX7100 hu
That should just about cover everything.
1 - 20 of 255 Posts
