What's the code?
Very likely by spraying down the breather tube (no gas line on the throttle body) you dislodged some gunk inside the tube and it could be clogging the breather port.
You didn't spray the electrical connector or throttle motor did you?
As for the copper brush, next time use an old toothbrush. It should be fine but depending on the alloys, the brush could be harder than the aluminum of the TB.
