Hello everyone. I am having a problem with my rear O2 sensor. i have replaced it twice now and i am still getting the check engine light for the rear sensor. please help
If you don't know the code, how do you know the problem is with the rear O2 Sensor. How do you know what is causing the "check engine" light? Without a code, there isn't any way to tell what the problem is.i dont know the code
X2What P code are you getting?
I cant really make a guess without knowing if it's a correlation between sensors, a bad heater circuit, or a malfunction code.
Go back and get the P code not a description. There are about 6 codes that pertain to the O2 sensors. Also autozone employees typically don't know their ass from their elbow.i had autozone read the code and they told me it was for the rear O2 sensor.
Here's the GM OBD-II P-Code list; which code do you have?i had autozone read the code and they told me it was for the rear O2 sensor.
