Well since I never put together a build for my truck, I decided it was time
Bought this truck in 2009 only because my 98 Blazer needed a lot of work to it. I found it at dealership for only $12,900 with 2600 miles on it.
Truck info
2009 Granite Black Ext Cab
2.9l
The day I bought her
First thing I did when I got home, I got online and started shopping for some new audio (I hate stock) I ran across (what seemed to be nice) touch screen double din radio (it didn’t last long)
I had an 740watt Pioneer amp laying around so I threw it in then went Best Buy for a sub. No one makes a sub box for an ext cab so I searched the internet which led me to this fine website we know as the Nation.
I ended up with a simple box I had made out of concrete piller tube and painted it black
While I was at Best Buy they had a set of 6.5 and tweeters on clearance for $29 so why not upgrade the door speakers while I am at it.
Then I bought some inserts for my grille and plasti dipped my bowtie
I had a lady in an Expedition hit me from behind so I went with a roll pan
It looked kinda funny with factory rims so I found a set on craigslist for $400 with tires
While I was on craigslist, I found a 2/3 drop kit for $100 (blocks and springs)
Ended up buying the bottom insert to make it look a little better
I ended up plasti dipping the rims to make it look like something different
And again about a year later
I got tired of those rims, they were 9.5 wide and I didn’t like the way they stuck out so I picked up some Maas 031B
Found another member selling his truck (Cuzican) and was looking for stock parts so I met up with him and switched out the bumper and grille. I ended up with his back up lights and rear view mirror. I added some LED tail lights and LED license plate light at some point
And I found another member parting out his truck and I ended up with his hood and all red 3rd brake light
I decide that I would cut my inserts to fit the extreme grille and I busted out the plasti dip again
Chrome on the wheels wasn’t my thing so I removed the inserts
Picked up a set of LCAs from another member
I had to get some smaller tires since it rubbed like crazy up front
I had bought some flares at some point, I tried them on and didn’t like them so I traded Ivan for some LED work on my cluster & white needles
Months after I bought the beltech drops leafs, I finally got them on after I did my notch
Only drove it one day and them my clutch went out….it sat for about a month then changed it out.
At some point I added the following (not pictured):
10” Pioneer DVC (got this from Bluesteel)
JVC double din
6k Low beam HIDs and Fogs
Billet Shifter
Low Pro crossmember (got this from Hotrado)
Painted the brake calibers and drums
Here are some current pictures:
With Ivan
And a picture I did about 5 years ago of what I wanted my truck to look like (I found it about 3 months ago)
I am currently building a fiberglass speaker box for a 10” sub to fit between the seats since nobody sells one for an ext cab
Truck info
2.9l
JVC double din
Billet Shifter
With Ivan
