21 - 27 of 27 Posts
Discussion Starter #22
form the km comment are you from Canada? is it a 4x4? X-Cab? or CrewCab? are you using a digital gauge for temperature readout? i'd suggest checking antifreeze ratio, you may have too much water. with the engine cold, remove the radiator cap and siphon a sample from there. the prestone gauge is pretty accurate.
Sorry I did not get back to you. I only seem to get some emails with people responding. I was actually planning to get one of those today as I'm doing a coolant flush within the next week. Thank you for the advice.
Discussion Starter #23
I had what I considered poor mileage. I also performed the usual in-depth tuneup(including cats and o2 sensors) as you did and the mileage increase was not what I expected, but after doing tie rod ends and upper ball joints and then a front end alignment, that was when fuel mileage nearly doubled.
Wow. Never would of thought those parts would of made that much of an improvement. How many miles can you get on a tank? I fill up at about an 1/8 of a tank. I'm lucky to get 350 km.
I was seeing around 11-12mpg and now see anywhere from 18-21 mpg. I fill up when the fuel level warning comes on at right around taking 13 gallons to fill. I live in the Catskill mtns of NY so the fuel mileage can vary greatly, depending upon the destination and what type of roads have to be traveled upon.
Sounds like a thermostat either stuck open or opening too early. Ours would throw a Code that temperature wasn't getting up to temp in proper amount of time.
Discussion Starter #26
The truck heats up quite quickly, way quicker then my parents new vehicles. Just stops 2 ticks below half.
Discussion Starter #27
Update: Changed thermostat and put in new coolant, dummy gauge is still a little off but the temp via OBD2 is sitting around 200. Gas mileage is improved and I swear it feels quicker, ass dyno could be wrong though. Thank you to everyone who helped me out.
21 - 27 of 27 Posts
