I have a 2005 colorado base model (work truck style). It is a 2wd, 2 door, and it is alot lower in the front end than the back. Is their any way to level the front end out with the rear without lowering the rear?
Im sorry i forgot to state that with your W/T rims you wouldnt be able to fit a 255 I dont think. I have the zq8 wheels which are quite a bit wider than yours...You would need to upgrade your wheels to at least what the z85 has in order to fit these i believe.what would be the max tire size i could run like it is then?...215's
