I have a few questions about the QA1s and was unable to find the answer I was looking for. Thanks to Brewer for his drop components thread that I got the most info.
Info on the truck: Im running stock suspension right now, I have 245/40/20 tires. I plan on throwing 2" blocks and Monroe air shocks in the rear. I might possibly be going to 18"s to get a lower stance. I would like to get anywhere from 2"-3" of drop in the front.
CORRECT ME IF I'M WRONG, BELOW IS WHAT I HAVE IN MIND WHEN IT COMES TO THE QA1
From what Ive read, the QA1 will give let me adjust from stock height, to about 2.75" below stock height. The stiffness can also be adjusted in order to make them ride softer or tighter.
Brewer posted this info in his thread about QA1 parts:
Front QA1 coilovers:
DR7855P Proma Star AL single adjustable coilover shocks - $152.95 each
DDR7855P Proma Star AL double adjustable coilover shocks - $275.00 each
9029-146 4" Stud Mount Conversion - $26.10 each
7888-110 SPANNER WRENCH & THRUST BEARING KIT - $45.95
*Request bottom bushing bolt sleeve 9/16"
Question 1: What is the different between the single and double adjustable shocks?
Question 2: Do I need the stud mount conversion, spanner wrench & thrust bearing kit, and the bottom bushing bolt sleeve 9/16" to complete everything in order to install them.
Question 3: What springs do I use, I don't see any springs that come with them on the Summit website.
Question 4: How easy is it to adjust the ride height and the stiffness of them?
Question 5: What is the total price-wise of what I'm going to spend to get everything needed.
Don't bash me too hard on this guys, after a few hours of searching the threads I DID find information on them, but it was difficult to find the answers I was looking for.
