So right now, I have a 3/4 drop on springs and blocks. I want to squeeze another inch drop, and my plan is to get some zq8 leafs and some adjustable drop shocks. To correct the lean, I'm going to get spacers, as I only have a half inch lean, and the drop shocks only adjust in whole inches if I am correct. So I will raise the driver side up a half an inch with the spacers, then drop it an inch with the shocks for about a four in the front. I know ill be needing a notch in the frame for axle slap, more than likely a low pro crossmember, and to relocate my brake lines under the frame. Is there anything else that I am forgetting that I should/need to do?
