I have a 2008 Chevy Colorado I4, manual transmission. For the last couple of years (pretty much since I bought the vehicle), I will randomly get a hesitation in the middle of the acceleration in my lower gears. It will start to move, then partway in the acceleration it will feel like the truck almost stalls, sometimes repeatedly, but if I feather the gas a bit then it will kick up just fine and go back to normal. Once up to speed the truck seems to run just fine. No check engine lights.
This only happens randomly, not consistently and I can't repeat it when I want to. I did notice it usually happens on hot days, but has happened on a cold morning or two. For example, it has run fine here in Colorado all winter, but yesterday it was the warmest it has been in a while (high 70's) and this hesitation happened to me twice on my drive home from work. Today it is snowing and everything is fine. Other times it can be in the 90s all week and run fine.
So far I have replaced spark plugs and ignition coils, but havent done much else as I have had bigger fish to fry on other vehicles. I think I am going to clean the MAF sensor next, and I saw a post mentioning the vapor canister so I will clean that and make sure the vent is working properly. Like I said though, no check engine lights and no idling issues, so I am not sure where else to look. Any suggestions?
