1 - 20 of 23 Posts
Does anyone know if it's possible (as in not very hard) to swap our rear end for the rear end out of the S-10? Just wondering because it seems that an H3 swap would be rather expensive and I'm wanting to go with rear discs. Also doing the swap would convert to 5 lug (at least in the rear) and I don't think it'd be too hard to figure out how to do the same to the front (probably as easy as a hub swap I thinking). Anyone have any opinions on this?
:yeahthat:
Also, if you're talking about going with the 7.625 10 bolt which is the most common in S10's I think you'd be wasting your time. It's a pretty weak setup. If anything I'd look into an 8.5" 10 bolt from a full size, you can get them in the right lug pattern although you may have to have it narrowed.
Discussion Starter #4
:yeahthat:
Never really thought about using the full size rear end ... hmmm. I think I know where one is for free. :)
you know we do have a rear disc upgrade right? although i believe you have to upgrade the fronts and the rears altogether.
It'd be better all around IMO. It's a lot stronger if built with the right parts and has a ton of aftermarket backing it so you can get almost any gear ratio you want with any style of LSD or Locker.
tell us more about the dics brake upgrade
Not really anything to tell. It's been out for almost 2 years, it's made by Stainless Steel Brakes Co. (SSBC). It's not cheap and few are willing to pay the price for the full front/rear setup.
Discussion Starter #9
Exactly why I'm looking at other options. AND the fact that if I used a full sized rear it'd be stronger along with more aftermarket options.
could also try swaping in TB axles and front spindles it might work
Discussion Starter #11
Sorry it's early, but what is TB?
TB = TrailBlazer. It has the same rear axle as us but a different lug pattern.
Discussion Starter #14
O ... haha. Now I feel like a 'tard.
If you don't mind losing a lug, why not a Ford 8.8. Most come with disks, they are stronger and for really really....really cheap, you can make them almost bulletproof.
Discussion Starter #17
I'd have to change the front over as well ...
Why do you need the whole rear axle? Get all of the brake components from it, redrill the rotors for the correct lug pattern and see if it bolts up. It's the same axle as us so I don't really see why it wouldn't.
Discussion Starter #20
I want the whole thing because it has the 4.1 gearing in it.
1 - 20 of 23 Posts
