Can someone point me in the right direction on this....I dont have an owners manual to know which fuse to check. Or is there something else it could be. Thanks guys.
Thanks. My rearview mirror has 2 little map lights on the bottom of it. They arent working and i wad just asking which fuse ran them or if it was another common problem I should check.
Power comes from the BCM. If you are sure that the bulbs are good, check ground G105, located in the engine bay, on the left fender wall, outboard of the Brake Control Module. Look for a small black box like this one, mounted with one bolt. Remove the bolt and clean the surface of the fender wall and the tab on the box. The area is tight, but try to check the wires also.
1 - 4 of 4 Posts
