1 - 10 of 10 Posts
I've just marked and drilled the holes to mount my Redline Tuning hood prop kit.
At the location on the fender lip where the lower bracket goes (centered at 11-1/4 inches from the hood corner) there's an existing hole already there under the rear-most bracket hole (nearest the firewall).
Same hole, both driver's side and passenger.
The rearmost edge of that hole lines up nicely with the rear hole in the bracket.
Anyone else have this?
I can't rivet there, the hole is an elongated hole much larger than the rivet-head.
Just as well, I decided I want some stainless Allen button-head machine screws for the fender brackets anyway. I'll have to use a largish washer under that existing hole.
I'm off to Lowes to pick some up now.
Can't say I'm too impressed with the contour of the hood brackets.
I think they could have put some effort into making them conform better to the contour of the hood rib where they have that angle bent into them.
U'll have way more support if u wedge something between the flange the brackets attach to and the fender surface below. Doubt if any "stiffening" is needed though.
Discussion Starter · #5 · (Edited)
I agree on both counts.
The backing plate is primarily to eliminate the two nuts I have now on the bottom of the screws (under the fender lip).
I'll drill and tap the holes in the backing plate.
While I'm at it though if I make it three or four inches long (or more... I haven't yet measured to see what the max would be) then it'll help distribute the load.
Cheap and super-simple to do, so why not?
· Formerly Metal_EMT
Any idea what years have this slot? My 04 did and I just moved the mounting position slightly to accommodate. I could forward the info to Redline Tuning to have them adjust their instructions.
1 - 10 of 10 Posts
