1 - 11 of 11 Posts
FedEx delivered the lifts late today (thanks again HK Titan for the group buy assistance) and I'm just doing a little preliminary mock-up per the instructions. Measured 11 1/4" and marked but when I center the ball mount with the mark, one of the rivet holes is over the hole in the fender flange.....no meat/metal for that rivet to grab. Moving the ball mount toward the rear 1/2" seems to solve the problem. Do some years have the hole in the fender flange and some years don't?
Discussion Starter · #2 ·
FWIW, I knocked a 1/2" off both measurements in the instructions. Install went easy/ended up perfect.....now have one handed hood up/down and the hood opens 3"-4" further than with the prop rod.:th_woot::th_woot::th_woot:
What i did was center the ball stud over the opening area and install it there.
I agree with James it is indeed one of the best mods you can make. Can't count the number of times I hit my head on that rod when working under the hood. Had mine since 2010 and they still work great and no shift seal leaking either.
Formerly Metal_EMT
yeah I remember having that problem and just moving a bit to clear it. i could email Redline this info. What years have this hole and who doesnt?
Darth Vader
My 06 had the holes on both sides.
04 had the hole on both sides
Discussion Starter · #10 ·
....so does '09.
Just installed mine an hour ago.
I used M5 stainess button-head Allen screws for the fender brackets instead of the rivets.
Put a large washer under that existing hole..
Nice, nice, nice!
In a month or three when I'm back home I plan to fab a nut-plate to go underneath there.
1 - 11 of 11 Posts
