Lay into it hard. Does this mean wide open throttle?Whys it that if you lay into it to hard that the truck goes into reduced power mode. How can i delete this acceleration govenor?
If i stomp on it to hard it goes into reduced power mode. It can occur from a dead stop or i can already be moving and just step on it real hard and will do it. It seems like ot shuts down a cylinder and runs all funny you can have the pedal to the floor and it barely goes after that. I have to shut vehicle off take key outta the ignition open the door close it wait till the inside light goes off then i can start truck back up and it will be clearedLay into it hard. Does this mean wide open throttle?
What is the truck doing that is reduced power? When does the power come back on?
No car manufacture makes a vehicle that will reduce power when accelerating, unless there is a traction control system on that particular vehicle.
Acceleration governor, what is this? Does your vehicle have traction control?
I have never had any reduced power on my coly, even when doing donuts or 100 foot burnouts..
Wait...you have a MAF code?Hahahha i wish i knew cause it comes up on my dash as power reduced. Ive had the conputer read but not while that was up a s the only things were mafs because i have an aftermatket intake, termastat , and o2 snsor
