1 - 5 of 5 Posts
My girlfriend had some flooring where the tongue and groove broke and was not flush anymore. I had the bright idea to use super glue. I ordered some watery thin stuff with great capillary action. I drilled a few small holes and put this stuff in. It worked well but some got on her floor. How to get it off without removing finish?
If the flooring has a clear coat on it, like some do, you might be able to get it to flake off. I'd try some goof-off in an inconspicuous area and see if that takes it off without dulling the finish.
Good luck man!
CALI BOSS
Moisten a cotton swab with acetone. Apply the acetone directly to the dried glue. Blot the area immediately with a cloth until the softened glue no longer transfers to the cloth. Repeat applying acetone and blotting with the cloth until all the glue is removed.
Sent from my SM-N960U using Tapatalk
That'll work. Goof-off is an acetone based product. Just trying to give him an item that he may already be familiar with an may have on a shelf somewhere around the house.
1 - 5 of 5 Posts
