Here is my first review of Surf City Garage's new Professional Line.
I got my 3rd Pro Line order yesterday! Order some Exterior Trim Conditioner, APC and Tire Dressing!
Tonight I decided to give all of them a try but I decided to do a head to head comparison of Adam's Polish SVRT recommended product for Trim against Surf City Garage Exterior Trim Conditioner! Jump right into it.... Surf City Garage Professional Exterior Trim Conditioner took home the Gold Medal by a long shot!
I started out by cleaning a section of window trim with APC. I applied Adam's Polish SVRT to the left side of the trim and then put down a piece of tape to separate the SCG ETC and then wiped them down to remove the excess... Both were applied with a MF Foam Core Applicator, both were applied with the same amount (Pea size drop) and same length of trim (10in).
Adam's Polish SVRT dried sort of blotchy or spotty and gave somewhat of a oily rainbow that showed up in the sun. Exterior Trim Conditioner on the other hand dried darker, shinier with a very smooth and solid look, usually to achieve these results with Adam's Polish SVRT I would have to do 2 or 3 applications of the product. Surf City Garage Professional Exterior Trim Conditioner only too 1 pass and very little product to achieve the look I like. Also that same Pea Size drop lasted me for 2 entire window trim.
Conclusion:
Surf City Garage Professional Exterior Trim Conditioner is by far superior to its competitors. ETC gives a darker shine right off the bat and does not require multiple application to achieve your desired look. Also to achieve the desired look it takes far less product. I used a Pea Size drop on a MicroFiber Foam Core Applicator for 2 windows and thats all that was needed.
Left: Adam's Polish SVRT - Right: Surf City Garage Professional Exterior Trim Conditioner
Pea size drop of Exterior Trim Conditioner on a MF Foam Core Applicator.
Conclusion:
