1 - 4 of 4 Posts
Have access to rims and tires off stock 2001 Yukon. Size 265/70R16. Will these fit my 2005 Chevy Colorado Z85 2WD stock crew cab? OEM size 225/75R15. Thanks for the help.
First, the wheels need to be bored to fit on your truck. The Coloado/Canyon wheel hub have a unique hub, larger than other GM vehicles. So GM wheels don't just bolt right on, although the bolt pattern is identical. Go figure....
Second, too big for a stock height 2wd non Z71. Your tire is current tire is 28" tall, the new tire is almost 31" tall (and 10.4 wide).
It's 8.2% larger. If you put it on, your speed will be off by 8%. But on a stock height, that's a lot to ask to fit.
Maybe it will cram in there, but is likely to rub depending on the offset of the Yukon wheels.
yep will rub on sway bar and frame so no lock to lock best to get smaxx lift 2.5in and ur good to go
1 - 4 of 4 Posts
