My truck has been doing this a lot lately as well. But only when it's hot outside. I live in AZ so it's been over 100 lately. But when I get up at 5 AM and it's 80 outside, it starts instantly.
I'm going to clean the TB and replace the fuel filter as well. It's got 100,000 miles now and all I've ever done is change the oil and replace the spark plugs once and clean the MAF. I wonder if I need TB cleaner or if I can use the MAF cleaner. My idle is low lately too. And for some reason if I brake hard it will go down to 500 RPM and seems close to stalling.
It's throwing a P0300 and a P0128
Also, when it's being a bitch, the passlock light will stay on sometimes.
Have you guys seen this?
http://www.355nation.net/forum/serv...em-driveability-issues-mil-multiple-dtcs.html
Hopefully I wont have to pay for that procedure
Also, it's not my battery cause she'll crank and crank and crank all day. Usually it starts and immediately dies. I repeat that till it stays running. And once it's running if I stop somewhere and run in really quick, it will start again easily.
I think the strangest thing is it only happens when it's really hot outside. It's been like that for a while buy it's worse lately.
