I hate to see this. I have these exact lights going in the truck this weekend. I've used 3m super silicone with a syringe on the seam and waxed them. I'm not going to be pleased that if after all that a tab breaks on them.DRL popped out again....
Busted clip...
On my DRL's the plastic spring clip never seemed to latch securely. A little nudge and they'd pop out. This time, I took a small square file and cut a sharp edge in them to help them latch better. Then I doubled-up with a big ole glob of silicone. They ain't popping out again.I hate to see this. I have these exact lights going in the truck this weekend. I've used 3m super silicone with a syringe on the seam and waxed them. I'm not going to be pleased that if after all that a tab breaks on them.
Do you have any suggestions on how to prevent this from happening Rshadd? I recently put DRL covers in, and they are a tight fit. I may hold off on installing the DRL covers to keep pressure off the DRL lights.
Edit: I noticed the adjuster did not seal to the lights very tight. for better or worse I've put silicone around the whole mechanism.
Great info! Thank you. I'll keep an eye out for this issue when I install them this weekendOn my DRL's the plastic spring clip never seem to latch securely. I took a some file and cut a sharp edge to help them latch better then doubled-up with a glob of silicone. They ain't popping out again.
K&N Filter Cleaning...
It's nice to have two of these filters, so one's always ready to go.
