On mine, I think AFR was a stock gauge.
Is there a code for Transmission line pressure for a 2011?
If so, what are the normal values, and what is the high limit?
My inTune just updated and I can tune my ECM, and I don't want to push it.
I thought this was a stock feature of the scangauge2, but it looks like my brother added it when he had it on his X-Runner back in the day.can't seem to get the AFR to work, on my 2010
How did you get oil life to work? I've never been able to, it just stays blank.I've gotten oil life to work as well as trans temp and air fuel ratio. What you mean about you tps sensor? While running it won't be at 0 because the motor is running and will have some throttle. I can look at mine tomorrow to see what my base is if you'd like.
It works on the VPW protocol trucks. I think that is 2007 and down. Both have tradeoffs.How did you get oil life to work? I've never been able to, it just stays blank.
The CANSF fuel level worked. Might be able to put into a VPW format and get it to work.
I tried I think 3 different ones and couldn't get anything. No big deal
See if this works. I just took the CANSF code and changed it to VPW. If they used the same PID, it might work.
Fuel Level
TXD: 6C10F1012F
RXF: 0441052F0000
RXD: 2808
MTH: 006400FF0000
Try it this way also. May not need the extra 0000 on the RXF.Still nothing. I'll go through the codes again tomorrow to see if I missed something.
Bringing this back up after a couple years. I just now found this thread and wanted to thank @FrEaK_aCcIdEnT for posting these.ok... Here is the commands for Oil Temp and oil Pressure. I also have Relitive Throttle position working, but I have to get it from the pickup tonight. Will post more as I get them.
Engine Oil Pressure
TXD: 07E0221470
RXF: 046205140670
RXD: 3008
MTH: 001D00320000
NAM: EOP
Engine Oil Temperature
TXD: 07E0221154
RXF: 046205110654
RXD: 3008
MTH: 00090005FFD8
NAM: EOT
I now have mine constantly displaying Water Temp, Oil temp, Trans temp, and Oil Pressure. I am one happy camper!
