Hopefully this will make you feel better. I am a 37 year old woman who just recently pulled all the interior out of my truck (by myself). I had never pulled the dash out of anything before and I was very nervous, but was determined to do it. I printed the thread on dash removal and proceeded from there. I taped and labeled certain bolts together so I'd remember where they went when I put it back together. I used Krylon Fusion paint as you don't have to use primer. It's made for plastic. I disconnected the battery first as the airbag scared me too. With the battery disconnected, the airbag will not deploy. I did notice there are 6 bolts to the airbag...not 4 as in the thread and I ripped the door off my airbag trying to pry it out. So I learned the hard way and I'm passing this info onto you. I also would recommend dropping the steering column which is only 4 bolts. It makes getting the dash in and out easier. Here are some before and after pics, and pics of the 2 hidden airbag bolts to make sure you don't miss. If you need me, pm me and I can help you further. I just did mine a couple weeks ago so it's all still fresh in my mind. Don't give up man.
Before:
Don't force the airbag. It's not supposed to come apart like this.
Here's where the hidden 2 bolts are behind the airbag. One on each side. You can get to them when you take out the radio and the panel on the passenger side.
This was the scary part...when I looked at the mess I made.
Putting it back together.
The finished product.
You can do this man. I promise.
