S
Spyman8
·Guest
Will seats out of a 2005 Xtreme fit in a 2006 Z85 without any modification?
yeah, in 06 they added a weight sensor in the passenger seat, so everything is different including the belt. I think the drivers side would be the same if you get the belt with the seats.I thought it was in the correct section?? So I will have to switch the sensors over? I was planning on keeping the belts too.
I'm pretty sure all you'd have to do is swap seat tracks from the current one's to the new seats. I think the bench seat tracks are the same as the bucket seat tracks.Also make sure the trucks are the same cab configuration. Like Reg cab seats wont work in an x-cab.
actually, all the tracks are the same. and you can put any seat in any cab. The problem comes because crew cab (and maybe ext cab) trucks dont have the seat fold forward option so its hard to access the area behind the seat.Also make sure the trucks are the same cab configuration. Like Reg cab seats wont work in an x-cab.
I already said you have to switch the wiring anyways, because its an 05 into 06. So he can use the seats out of any cab. I have crew cab seats in my truck, they work fine.No, the problem comes from the airbag systems. The reg cab has the option to turn on and off the passanger airbag where as the x-cab/crew cab has the sensor only and no switch. The wire harness are different. I tried swapping seats with a friend with an 05 x-cab and the seats bolted in fine but the wire harness didnt match on the passanger side.
